Short Circuit In Secondary Wiring - HVAC - DIY Chatroom Home Improvement Forum
Old 03-14-2011, 10:58 PM   #1
Still Learning
Short circuit in secondary wiring
Hey i went to a call today for a system that wouldnt fire up. When i got there i found a blown fuse on the circut board and an error code that said short circut on secondary wiring. I saw that there was a wire going from the common on the circut board to the o/b terminal on the t stat. I disconnected it and the system didnt blow the fuse. My question is why would the system run for 2 months without tripping the fuse? Do you think that cool mode pulls more amps on the secondary?? Cause i replaced the fuse and before removing the wire the system ran in heat mode, bit when i put it to cool mode the fuse popped
thehvacguy is offline   Reply With Quote
Old 03-14-2011, 11:08 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
O is going to be switched on with cooling, thereby blowing the fuse if it was connected to common
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 03-15-2011, 02:52 AM   #3
Still Learning
I apologise for not clarifying, its not a heat pump, its a natural gas furnace with electric a/c
Old 03-15-2011, 05:39 AM   #4
An old Tradesmen
Rewards Points: 6,560
Many thermostats energize O on a call for cooling weather or not they are set up for a heat pump. So as 126 said, it blew the fuse because the O terminal energized on a cooling call. Some thermostats energize O as soon as the system switch is set to cool, weather or not the thermostat is calling for the A/C to run.
Is the furnace equipped with a VS blower? If so, it may have been miswired in an attempt to control blower speed in cooling mode.
Old 03-15-2011, 01:44 PM   #5
I'm Your Huckleberry
Rewards Points: 2,270
Can I ask why would there would be a stat with an o terminal with a wire hooked to it if the system is not a heat pump?
Doc Holliday is offline   Reply With Quote
Old 03-15-2011, 01:45 PM   #6
AKA HVACTECHFW
because it was not wired properly from the beginning
IT IS WHAT IT IS
Old 03-15-2011, 01:50 PM   #7
The O terminal is an accessory connection. Some stats have them in heat and cool.
hvaclover is offline   Reply With Quote
Old 03-15-2011, 01:58 PM   #8
Still Learning
Um, to the best of my knowledge all furnaces in my region have vs motors in them. Usually low speed is for heat, high is for fan, and med/low is cool. If you meant to say two stage then no, its a single stage system.
Old 03-15-2011, 02:00 PM   #9
Still Learning
Haha because the homeowner wanted to save money by replacing the thermostat himself. Thats fine by me cause i made more money off of him fixing the problem
Old 03-15-2011, 02:05 PM   #10
Hey Surfer Boy, you are a describing a PSC multiple speed motor.
Variable speed would be an ECM half have D.C. motor.
Lay off the medical grass dude.
The Following User Says Thank You to hvaclover For This Useful Post:
hvactech126 (03-15-2011)
Old 03-15-2011, 03:30 PM   #11
An old Tradesmen
VS systems often need power to the O terminal for the blower slow down for enhanced dehumidification ability.
Old 03-15-2011, 03:39 PM   #12
Are you stating that as the reason that the fuse blew?
Old 03-15-2011, 03:48 PM   #13
An old Tradesmen
The fuse did blow because the O energized and was connected to the common at the board.
I posted what the may have been thinking or trying to accomplish when they connected the O terminal.
Heck, they may have thought the O was the C terminal.
Old 03-15-2011, 04:02 PM   #14
Just checking. It was obvious that a hot 24v going back to a neutral common would blow a fuse.
Your response (at least to me) was not clear in that regard.
Thank you for clarifying,
Old 03-15-2011, 06:40 PM   #15
Still Learning
You dont have to be a dick im only 23 i have years of experience in front of me. And by the way, just because i live in la doesnt mean i surf and smoke pot. Actually i dont even skateboard. I build homes
Need a wiring diagram Mooreski Electrical 47 02-01-2015 04:07 PM
Wiring Help, Changing a Dryer and/or Stove circuit to something else shunut Electrical 10 01-08-2011 04:06 PM
short circuit question bryan1282 Electrical 1 10-05-2009 06:14 PM
Wiring a single pole switch into a 220v circuit rlmorgan Electrical 38 10-15-2008 08:59 PM
wiring a gfci outlet in circuit bobo Electrical 12 08-31-2005 09:38 PM
