#1 |
It was a dark and stormy
Short circuit current for an HVAC 24 v transformer?
"On paper" it's about 25 A.
Anybody measured this? |
#2 |
Clearify, Yowzie.
Just slow, not stupid. |
#3 |
An old Tradesmen
Hope that was suppose to be 2.5 amp.
#4 |
For 40 VA @ 24 vac the current is 1.7 A. The rated 24.0 v only applies when the transformer is loaded to its rated value of 40 VA.
If the open circuit voltage for one of these is, say, 26 vac then the internal impedance of the secondary is (26-24)/1.7 = 1.2 ohms. 26/1.2 = 22 A of short circuit current. If it's 27 V o-c then it's 1.8 ohms and 15 A short circuit current. I've never tested one of these HVAC transformers. And this arith. doesn't apply to bell transformers because they shut down if they're shorted. |
#5 |
An old Tradesmen
Go to radio shack. And get yourself some resistors. And test a 40 VA transformer.
It will burn up before you reach 25 amps. |
#6 |
An old Tradesmen
While a dead short amp draw, will be higher then a load increase burn up.
Your applying a DC formula. It is used on A/C transformers, as many DC formulas are applied to A/C. There is always a difference is actual outcome though. If you are supplying 120 volts to the primary, as measured by a standard meter/or true RMS meter. The transformer primary is actually subjected to 170 VOLTS at peak and bottom sine. |
#7 |
Hvac Pro
You have one in your furnace. Let us know how it turns out, Yoyzie.
"Cut it twice and it is still too short". To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#8 | |
Short circuit current for an HVAC 24 v transformer?Quote:
Can you imagine how mad my frau would be if I were somehow remotely responsible for our AC to suddenly stop working after I went into the basement? She's already asking questions about the catapult that I'm testing in the backyard [powered by garage door springs] and is openly wondering where the puppy went. http://www.youtube.com/watch?v=F5Y_4d9UhEA Now, really, how would I know where the puppy went? I e-mailed an HVAC manuf. whose name kind of rhymes with. . .dunno'. . .warrior/carrion/Vikky Carr/sumpin' . . .with my question. Last edited by Yoyizit; 07-18-2010 at 03:55 PM. |
#9 | |
Xtreme DIY'r
#10 | |
You gotta use Impedance and Reactance for Alternatin Current Yowzie. But that is an interesting topic for discussion. We all have TRANSFORMER FROM HELL horror stories we could share I'm sure.
#11 |
Short circuit current for an HVAC 24 v transformer? |
#12 |
Short circuit current for an HVAC 24 v transformer?Dude don't get him started! The next thing we'll see is Da Vinci style drawings and lonf drawn out equations!
#13 | |
#14 |
Look to your east - I'm sending you a cinder block at Mach 1. Allow 40 minutes for the flight time.
#15 |
My wife said it would not match our existing stone work----better make it a hard baked red brick instead.
| Display Modes | |
| Short circuit? | jlmran | Electrical | 7 | 02-08-2010 01:04 PM |
| Can I change where power enters a branch circuit? | RST | Electrical | 15 | 07-21-2009 08:38 PM |
| Real Basic Electrical question re: neutral wire | hellothere123 | Electrical | 22 | 07-21-2009 07:07 PM |
| HVAC Short Cycling | Redparis | HVAC | 2 | 02-26-2008 11:21 PM |
| So lost - electrical requirements please help | lapsis9 | HVAC | 4 | 12-20-2006 09:09 PM |
