Short AC Compresser Capacitor Life - HVAC - DIY Chatroom Home Improvement Forum
Old 07-04-2012, 07:03 PM   #1
short AC compresser capacitor life
I have an ~18 year old Goodman AC unit. It works fine, never been recharged and no issues with the unit itself. THe problem I'm having is that in its old age it eats capacitors more and more often. The original cap lasted ~14 years. The next one 2.5-3. The latest died after 14 months- basically one season.
I realize everything is made in China now, and these are $10 parts on ebay, but this still seems extreme. Is there anything that could cause premature cap death that I can control? Can I buy US mfg capacitors? Are they any better?
When I replaced this cap, I cleaned the male wire terminals on the starter/contact unit which were quite rusty. ANything else I can do or anything that can cause this?
Steve_P is offline   Reply With Quote
Old 07-04-2012, 07:10 PM   #2
JJboy's Avatar
http://www.motor-runcapacitorsonline.com/default.asp
Amrad
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 07-04-2012, 08:21 PM   #3
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Are you keeping the condensor cleaned out?
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 07-05-2012, 02:33 AM   #4
REP
What JJBOY is showing you is an American made cap.The Mexican,Chinese and other imports are real weak and has been the source of headaches for a number of years.
REP is offline   Reply With Quote
Old 07-05-2012, 07:14 AM   #5
I've seen capacitors that were bad right out of the box. As others have said, buy American made caps, and you'll get much longer life (of course, you'll spend about 4X as much, but you get what ya pay for).
scottmcd9999 is offline   Reply With Quote
Old 07-06-2012, 06:54 PM   #6
AKA HVACTECHFW
Rewards Points: 1,208
make sure the condenser coil is kept clean
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
The Following User Says Thank You to hvactech126 For This Useful Post:
plummen (07-06-2012)
Old 07-08-2012, 09:53 PM   #7
Yes, the condenser has been hosed out and is clean.
Thanks for the US capacitor link.
Old 07-09-2012, 06:06 AM   #8
"Hosed out" is normally not good enough to really clean a condenser. You will get much better results using a chemical specially designed to clean the coil. I believe the big box stores sell those chemicals, or you can buy a gallon of it a the HVAC parts house and mix it yourself. Just be sure that you use the correct ratios - they don't work too well if they're not mixed correctly.
Old 07-09-2012, 11:58 AM   #9
Rewards Points: 1,192
www.grainger.com
bobelectric is offline   Reply With Quote
Old 07-16-2012, 09:31 PM   #10
Rewards Points: 150
Grainger caps (Dayton and Genteq) are all made in China. Sad.... but true.
TJ_in_IL is offline   Reply With Quote
Carrier furnace short cycling between Low and High heat drtbk4ever HVAC 16 01-15-2012 09:38 AM
Short ciruit with Romex 10/3 cable and cable connectors virago Electrical 21 10-07-2011 09:01 AM
Furnace short cycling repman55 HVAC 12 01-21-2011 05:41 AM
Rheem 80% Furnace Short Cycling rlukas79 HVAC 0 12-19-2010 04:27 AM
Short Circuit but Breaker does not trip vino82 Electrical 6 01-29-2010 01:54 PM
