Shelf Life Of NIB Sealed Compressor? - HVAC - DIY Chatroom Home Improvement Forum
Old 09-05-2011, 07:40 PM   #1
shelf life of NIB sealed compressor?
new compressor (sealed still in box) manufactured 10 years ago vs one that was just manufactured. should or what would be the concerns in using the older one?
hoobie01 is offline   Reply With Quote
Old 09-05-2011, 08:08 PM   #2
Should be the same if the rubber plugs held the nitrogen for 10 years.
Old 09-06-2011, 06:09 AM   #3
Rewards Points: 1,216
Second that.
COLDIRON is offline   Reply With Quote
Old 09-06-2011, 01:55 PM   #4
Maybe....
Alot would depend on the manufacturing practices the day it was dehydrated and sealed. Mineral oil or POE? Even the best practices can have problems at times and a small amount of moisture would tend to lend itself to corrosion? No matter how careful we TRY to be. Just a thought.
TraneTech1 is offline   Reply With Quote
Old 09-06-2011, 03:31 PM   #5
REP
If you end up using it,make sure you install suction and liquid line dryers for possible acid contamination .I.E. Sporlan HH filter dryers.
REP is offline   Reply With Quote
powdered mud shelf life beerdog Drywall & Plaster 1 03-31-2011 10:34 AM
Does paint have a shelf life? Jawbreaker Painting 2 02-18-2010 03:31 PM
Do plastic pipes have a shelf life? ovahimba General DIY Discussions 2 09-28-2008 07:56 PM
New Compressor - Wrong Charge? shayneb HVAC 4 08-23-2008 08:13 AM
Quikrete Shelf Life jrepp Building & Construction 8 01-16-2008 01:40 AM
