Old 04-14-2011, 08:59 AM   #1
011010100110111101100101
Sheetrock above furnace code cite
Can someone please link me to the code that deals with sheetrock/fire protection above a boiler in a single story dwelling?
Is there any restrictions as to what can be "above" the boiler? I want to move the boiler to the new addition, but the spot it would go (corner end of home) is under a bathroom. With toilet, traps and PVC pipes I'm curious if that location will be a no-go.
-- Joe
anesthes is offline   Reply With Quote
Old 04-14-2011, 10:28 PM   #2
Wow. Nobody?
Old 04-15-2011, 02:25 AM   #3
HVAC Supermodel
unicursalhex's Avatar
We have to know where you are before we can link any local code. Here in WA there has to be a double layer of sheet rock in the garage or mechanical area. A sheet rocker should be able to work around the plumbing and it should be a fine location.
We generally don't tell people to go to other forums.
Mark it zero!
Last edited by beenthere; 04-15-2011 at 05:11 AM. Reason: removed suggestion to go to another forum
unicursalhex is offline   Reply With Quote
Old 04-15-2011, 05:12 AM   #4
An old Tradesmen
Don't have my IMC book infront of me. Locals codes may also have more restrictions, and your local code department will be able to tell you what their requirements are.
Old 04-15-2011, 06:16 AM   #5
Hi,
I'm in New Hampshire. We go by the IRC and I couldn't find any mention there. I didn't check the international plumbing code yet but I assume there is a specific fire code regarding this?
I see a lot of posts about 5/8" sheet rock, 3' around the boiler but I can't seem to find the source.
-- Joe
Old 04-15-2011, 08:30 PM   #6
An old Tradesmen
Here, in a single residence home. We don't have to provide any fire protection above the boiler. In a multi residence we do though.
Old 04-15-2011, 08:46 PM   #7
Wire Chewer
Red Squirrel's Avatar
Not sure about codes, but do consider the ease of access should the plumbing ever spring a leak or otherwise require some maintenance.
Old 04-15-2011, 10:25 PM   #8
concretemasonry's Avatar
Any state or municipality can over-ride model code like the IBC or IRC (with stricter requirements), but cannot go below the typical minimum standard, which is the worst you can do and stay out of jail or be fined for.
Check with the local building code authority for suggestion and variations.
Dick
concretemasonry is offline   Reply With Quote
3 - flash code, american standard freedom 90 furnace dfferg HVAC 25 03-05-2012 12:21 AM
Carrier 58PAV Error code 14 Hermmona HVAC 9 01-05-2012 11:42 AM
Payne Furnace error code 14 brian41527 HVAC 1 01-21-2010 08:32 AM
Olsen BFL 120 Furnace DaleB HVAC 12 12-19-2008 11:42 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
