Sheet Rock Dust - HVAC - DIY Chatroom Home Improvement Forum
Old 10-28-2010, 07:25 PM   #1
BWC
Unhappy
Sheet Rock Dust
Would it be ok for the Plumber to turn on my new Geo furnace system before we are completely done in side my new construction house. He does not want to do it untill all interior work is done but it is Nov and gettting cold out side. I could turn it off during the day while we are installing sheet rock if need be.
BWC is offline   Reply With Quote
Old 10-28-2010, 08:15 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,112
Sheet rock dust is the MOST horrible stuff to get out of ductwork/furnaces/coils etc. It literally is as fine as white flour and you can never get rid of it all. I would avoid it like "The Plague". Use a temporary electric or propane construction heater. Apparently sheet rock taping likes moisture and the propane flame gives off moisture which is good for it.
Old 10-28-2010, 08:27 PM   #3
biggles's Avatar
if it is a question of pipes freezing maybe..but if your cutting rock pre-heat the place before the work ..if you have a return grill in the hall ways double filter that to catch ANY dust besides the rock dust...if it is for comfort tell the workers to put on long johns
Old 10-28-2010, 08:27 PM   #4
An old Tradesmen
Rewards Points: 6,112
Great way to void the warranty.
Drywall dust will really screw it up.
Get some other form of temp heat.
Old 10-28-2010, 09:46 PM   #5
Hvac Pro
yuri's Avatar
Drywall dust when it gets inside any motor will destroy it. Like dumping grit into the bearings and windings. May void the warranty as they inspect a LOT of parts when they are returned for warranty nowadays. Dirt and lack of maintenance is NOT covered.
Sheet Rock Over Concrete atmironov Drywall & Plaster 3 08-13-2010 04:17 PM
wet sheet rock amy@jccturf.com Drywall & Plaster 5 06-11-2010 03:10 PM
Back Splash Tile Over Old Sheet Rock? Stcrosby Remodeling 3 01-03-2010 01:46 PM
Sheet rock (1/4") in trailer house sagging chrissygarden Building & Construction 4 08-19-2009 11:53 PM
Painting over messed up sheet rock. emilyiam Painting 2 03-24-2008 05:00 PM
