Old 09-30-2012, 09:49 AM   #1
Set up indirect water heater using Honeywell L7224/L7248
I have an older cold start Weil McLain oil fired boiler with a newer L7224/L7248 controller (the old controller died 2-3 years ago). Until recently I ran a separate oil fired Bock water water heater, but it is nearing the end of its life and I decided to set up an indirect water heater to save on oil and burner maintenance costs. My boiler system is set up with a single circulator pump. I have a spare zone that I plan to hook up to the indirect tank, which originally went to a basement heating zone that I never used. Think it will work if I simply just hook up the thermostat wires to the aquastat on the indirect tank, however, I would like to set up the indirect water heater zone such that it is prioritized over the other 4 house heating zones if possible. I see that there is a ZR terminal on the L7224/L7248 controller, but I am not quite understanding how to wire the indirect tank zone such that it will be prioritized. Would appreciate some advice.
jtauriello is offline   Reply With Quote
Old 09-30-2012, 10:14 AM   #2
Professional
a line voltage aquastat will be necessary that will send L1 power through to the ZR terminal with a demand for heat on the dhw zone. You have to go into the settings of the new L7224/L7248 to setup the priority on the ZR circuit.
see more here: pdf file
page 8 for a schematic
page 5 for adjusting control settings
You should install a separate circulator for the dhw zone.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Tags
honeywell l7224/l7248, indirect-fired hot water
Tankless hot water heater during winter when water shut off jdabs Plumbing 3 07-10-2012 01:50 AM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 10:55 PM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 09:42 AM
water heater drip kdange1 Plumbing 5 05-04-2010 04:24 PM
Indirect vs. Stand Alone Water Heater Clutchcargo Plumbing 0 11-24-2008 10:03 AM
