Set Points - HVAC - DIY Chatroom Home Improvement Forum
Old 09-24-2011, 08:01 AM   #1
Rewards Points: 129
Set Points
What differential do you guys recommend before aux heat comes on? I have an all electric two stage heat pump. It was a bit chilly this morning so I cut the heat on for the first time this year. If the set temp gets more that one degree away from the current temp, the aux heat cuts on. If I leave it like that, those heat strips will always be running ($$$$). I had some work done earlier in the year, so I think my set points got tinkered with....
poolecw is offline   Reply With Quote
Old 09-24-2011, 08:06 AM   #2
AKA HVACTECHFW
Rewards Points: 1,208
2 degrees and consider putting in an outdoor stat to lockout the aux heat strips until the outdoor temp drops below a certain point.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 09-24-2011, 02:18 PM   #3
An old Tradesmen
Rewards Points: 7,808
If you leave your thermostat set at one temp. Then the strips won't come on unless the heat pump can't handle the load, or it goes into defrost.
What are the points needed to keep in mind while installing onyx tiles? marconydamn Tiling, ceramics, marble 2 04-12-2011 08:52 PM
Ground/Neutral Connection Points on Main Breaker Old College Try Electrical 8 06-24-2010 08:59 PM
lowe's installation labor points, how are they calculated? lisacro General DIY Discussions 3 05-21-2009 08:25 AM
Helped Me points Knucklez Site Help and Suggestions 2 03-08-2009 12:47 PM
dishwasher gets stuck at 2 points in cycle Brbgriffin Appliances 1 11-19-2007 03:53 PM
