Old 11-16-2010, 03:30 PM   #1
Service tech won't repair furnace with cracked heat exchanger.
Have a Comfortmaker GUA080, installed 1993. Under maint. contract with Xcel. Furnace not working. They sent service tech who diagnosed bad Draft Motor - good news, is covered. Then he decided to check the heat exchanger, and found 1" crack in left cell. Then, said he can't repair the draft motor w/o replacing heat exchanger, may be unsafe, CO scare. Would have to order exchanger (he said probably under warranty with Comfort.) and draft motor. H.E. not covered by contract. Quoted $700 to install, or suggested get new furnace. I begged him to just fix draft motor, I'd buy a CO detector, so we'd have heat and buy us time to figure out what to do. He said against company policy. That was at 5 pm last nite. So he left, now, no heat. 56 inside -it's MN. Making decision under pressure. Repair or new?
GloBigRed is offline   Reply With Quote
Old 11-16-2010, 05:03 PM   #2
Professional
I can not repair any furnace with a cracked heat exchanger, LIABILITY!!! If you repair, understand that everything else or most everything in furnace is still 17 y/o. Average life is 15-20 years. The heat exchanger he will replace it with is the exact same will crack again!
hvactech126 is offline   Reply With Quote
Old 11-16-2010, 05:51 PM   #3
Hurry up get another opinion and quote.
COLDIRON is offline   Reply With Quote
Old 11-16-2010, 06:04 PM   #4
fabrk8r
fabrk8r's Avatar
No tech in their right mind would repair the inducer motor and start the furnace knowing the HX is cracked.
Cracked HXs cause death. The tech would be endangering your family's lives and be making himself liable in the event someone in your home was injured or died from CO poisoning.
AFAIK, for a licensed HVAC tech to knowingly allow a homeowner to continue using a furnace with a cracked HX is illegal in every state in the USA and probably every Canadian province as well.
If I were your repairman I would give you 2 quotes...one quote to replace HX and repair/replace inducer motor, and one quote to replace furnace. I would then leave a few electric space heaters with you until you got the furnace repaired or replaced, regardless of whether you accepted my quote or not.
BTW, make sure the person doing the repair or change-out checks the temp rise. The HX cracked for a reason.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
The Following User Says Thank You to fabrk8r For This Useful Post:
GloBigRed (11-16-2010)
Old 11-16-2010, 06:37 PM   #5
An old Tradesmen
You had a good tech out then.
When you have a cracked heat exchanger. Ain't no such thing as just make it work until I can make up my mind.
Just do the simple math. A replacement heat exchanger will have the remainder of the original warranty left. A new draft inducer, will have a 1 year warranty. There are several other parts that will still be 17 YEARS OLD. that can also go out anytime now.
Get a new furnace. And you get full part warranties on everything again. And have a more reliable furnace.
Get a couple portable space heaters and use them until they get your new furnace installed. Don't run them when your no one is at home though.
The Following User Says Thank You to beenthere For This Useful Post:
GloBigRed (11-17-2010)
Old 11-16-2010, 06:45 PM   #6
Hvac Pro
Yep, those units DON'T get better with age. Next it will be the gas valve and circuit board and pressure switch. Better off investing your $$ in a new one and check for gov't rebates. Illegal to start a furnace with cracked heat ex in Canada, we call the utility co, they come down red tag it and shut the gas off.
Old 11-16-2010, 07:02 PM   #7
Chicago, IL
Michael Thomas's Avatar
One more vote for: "Tech did the right thing".
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs
Michael Thomas is offline   Reply With Quote
Old 11-16-2010, 07:24 PM   #8
HVAC / Plumbing
He did you & your family a favor. Buy him a steak dinner. You could have gotten someone that just wanted to make a quick buck & replaced the v.m. Then, you may not have been around to have a new furnace installed
buy a new furnace 90+
kenmac is offline   Reply With Quote
Old 11-16-2010, 07:30 PM   #9
Hvac Pro
A steak dinner? I usually get the "deer in the headlights look" followed by the fred sanford "my heart, my heart" routine when delivering the news.
Old 11-16-2010, 08:00 PM   #10
HVAC / Plumbing
Yeah I know. I went to a call today where a company replaced several parts & never checked to see that the hx was cracked. I'll be replacing the furnace in the am
Old 11-16-2010, 09:36 PM   #11
Just got that look an hour ago along with the "we would like to get another year out of it". CO detectors going of in the house so they call for overtime service. Turned the blower on and the air is blowing out the vestibule right in my face( 39 year old york). Fired it up to get a reading for the ticket and analyzer hits 2400 ppm in the bad cell and 1900 ppm a foot in front of the furnace. If they didn't have those detectors there's a good change the whole family would be dead.
Old 11-16-2010, 09:43 PM   #12
Hvac Pro
It's the old "ignorance is bliss" attitude I suspect a lot of people have. They don't "really want to know" their furnace is a mess and can kill them because then they would have to spend money and not go drinking/gambling or whatever they else do with it. Being in denial kills people from CO, bad wiring and other preventable disasters. Smart people don't go that route.
Old 11-16-2010, 09:56 PM   #13
30 year tech
hvac122's Avatar
I vote for the tech you had out. He did the right thing. Give them the chance at the repairs or new furnace. Don't be mad at them, they may have saved your life.
hvac122 is offline   Reply With Quote
Old 11-17-2010, 07:10 AM   #14
Those old ComfortMaker gas pacs were notorious for heat exchanger issues. Your tech did what any astute tech would have done. I imagine you would rather be cold than dead.
brandonmcginnis is offline   Reply With Quote
Old 11-17-2010, 07:42 AM   #15
Totally agree with all the responses, all I am saying is I never get any big ticket item installed at my place without second opinions and at least 3 quotes from responsible contractors. I told a white lie never used contractor's always did everything myself. Well maybe once or twice.
Always use smoke and carbon monoxide detectors and keep the batteries up.
Replace Heat Exchanger or Furnace deccher HVAC 36 01-22-2013 11:35 PM
Heatpump vs Natural Gas - Energy Cost Spreadsheet zootjeff HVAC 8 11-19-2011 11:45 PM
Heil Heat exchanger gone bad. What to do? nichelob HVAC 51 01-19-2010 04:49 AM
Heat Pump Woes Zenica HVAC 50 01-27-2009 08:37 AM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
