Separete Zone For Home Theatre - HVAC - DIY Chatroom Home Improvement Forum
Old 04-12-2013, 08:06 PM   #1
Rewards Points: 150
Exclamation
Separete Zone for Home Theatre
Looked through the manual and understand it to a point. Was hoping to get some "polishing" from you guys.
http://www.smarthome.com/3038A/Resid...troller/p.aspx
Could this be installed to independently control the temperature and CFM of the HT completely separate from the rest of the house with it's own thermostat?
Thanks.
Mijotter is offline   Reply With Quote
Old 04-13-2013, 05:01 AM   #2
An old Tradesmen
Rewards Points: 7,824
Yes, along with the associated motorized dampers and bypass damper.
Old 04-14-2013, 01:42 PM   #3
Rewards Points: 150
Is this something a DIY'er could pull off or would I need a professional? What would I be looking at for cost of said motorized dampers and bypass dampers?
Old 04-14-2013, 02:04 PM   #4
An old Tradesmen
A DIYer can do it. cost will vary by brand, and supplier. Best to look on line and see what it will cost you.
Old 04-14-2013, 02:09 PM   #5
Rewards Points: 150
Wow so I could have a thermostat put in the theatre room and control the temp and air flow without messing with the house's?
Old 04-14-2013, 02:34 PM   #6
Rewards Points: 150
Would I also have to duct in a supply and return to the room from this unit as well? Does the unit get hooked up to the main furnace somehow?
Old 04-14-2013, 02:58 PM   #7
An old Tradesmen
You would have a motorized damper for the theater room, and one for the rest of the house(presuming that you are making a trunk line just for the theater room). Along with a bypass damper and duct.
Old 04-14-2013, 03:16 PM   #8
Rewards Points: 150
oh ok, so when I use the thermostat in the theater room the motorized damper opens right? What about a return? Just hooked up to the main return trunk of the furnace?
Old 04-14-2013, 03:19 PM   #9
An old Tradesmen
Yes,.
Tags
duct , hvac , split , thermostat , zone
Zone valve opens but doesn't fire boiler mikestorm5 HVAC 11 09-22-2015 06:37 AM
3rd zone not working properly MichaelChlopik HVAC 1 10-15-2010 05:59 PM
Adding new zone makapacs HVAC 0 11-26-2009 12:35 PM
need some help sorting out my new heating zone please wombosi Plumbing 3 04-23-2009 04:54 PM
help with third heat zone i just put in... wombosi HVAC 6 04-21-2009 12:02 PM
