Separating & Re-attaching A Cast Iron Base Board - HVAC - DIY Chatroom Home Improvement Forum
Old 11-25-2011, 08:43 PM   #1
Separating & Re-attaching a Cast Iron Base Board
I have a cracked cast iron base board (Burnham-Baseray). What's the easiest way to separate the cracked section (1 ft) from the rest of the baseboard? I removed the bolt in the back that holds the sections together and tried prying them apart, but with no sucess. Also, how do I reattach the new section? Thanks
Roundabout is offline   Reply With Quote
Old 11-25-2011, 11:30 PM   #2
Rewards Points: 582
need picture of baseboard...
Old 11-26-2011, 12:55 AM   #3
REP
You most likely have something called push nipple inbetween each section.These have been getting hot and cooling off for years and years.It might feel like they are welded but the sections will seperate with enough force.
REP is offline   Reply With Quote
Old 11-26-2011, 05:04 AM   #4
An old Tradesmen
Rewards Points: 6,518
Yep, move it back and forth several times, on the flat/face side toward you. It will begin to loosen. Then use a cat tail. Must replace push nipples. And they won't come out real easy either.
The Following User Says Thank You to beenthere For This Useful Post:
Roundabout (11-26-2011)
Old 11-26-2011, 09:03 AM   #5
Hvac Pro
yuri's Avatar
Rewards Points: 1,422
One of these??
Old 11-26-2011, 10:02 AM   #6
Second reply...first one didn't take?? Separated as suggested. Once it broke, it came apart easily. One nipple stayed in good section, so I'll need to remove it. Will try with vise grips. Today's project is to reattach with new baseboard and nipples. Wish me luck.
Hard lesson learned: Don't overtighten a bushing into cast iron...it might crack!
Yuri, thanks for the cats tail picture....worked like a charm...never liked that cat anyway.
Old 11-26-2011, 10:23 AM   #7
An old Tradesmen
Originally Posted by yuri View Post
One of these??
rofl...
Old 11-26-2011, 11:10 PM   #8
Got it Done. DIY Success
All worked out with replacing the cracked baseboard. Turns out separating the radiator sections was fairly easy by inserting a pry bar in the appropriate areas on the back. Removing an old stuck push nipple from the good section came off with applying heat to the baseboard section near the nipple. The only trick was reattaching the baseboards. You need a tool that forces the two sections together. A local Heating/Plumbing shop let me borrow it. I don't believe you could do it without the tool. To attach the sections. I inserted the push nipples dry into the existing radiator section and used a block of wood to pound them half-way into place. I inserted dry to help prevent them from being inserted too far into this section. It worked. I then applied some pipe dope to the push nipples sticking out and positioned the replacement section in place. I added the pipe dope to help the replacement section slide on easier. It worked. Once in place, i used the tool and cranked down and after applying all my weight and using a lever extender, the sections eventually went together. I added some valves to the run, just in case, I needed to isolate the radiator due to leaks. In the end, not needed. Except for a sore back lifting/moving the 12 foot section of baseboard, it was a DIY success. Thanks for all your help.
Old 11-27-2011, 08:32 AM   #9
Hvac Pro
yuri's Avatar
Sounds like a "Roundabout" way of doing things.
Glad you got it done.
basement bath- tying into old cast iron hethrm Plumbing 6 06-13-2011 10:19 PM
replacing cast iron pipe davemarz Plumbing 1 05-20-2011 10:16 PM
replacing/altering cast iron supply & return lines? jeffro83 HVAC 5 05-12-2011 07:14 PM
cast iron or pvc treerat Plumbing 1 03-29-2011 07:38 AM
smoothening cut cast iron pipe before mounting fernco coupling amakarevic Plumbing 6 11-15-2007 06:39 PM
