Sensible And Latent - HVAC - DIY Chatroom Home Improvement Forum
Old 11-20-2011, 05:47 PM   #1
Smile
Sensible and Latent
I have done a calculation
I have Sensible Gain 10,174
Latent Gain 2,409
Total Heat Gain 12,583
Toyal Heat Loss 32,721
I ran a program entered all the data
But I am much better at computers than HVAC
What are these numbers telling me
Brian
BSB00 is offline   Reply With Quote
Old 11-20-2011, 08:42 PM   #2
An old Tradesmen
Rewards Points: 7,376
That you need an A/c that can provide that sensible capacity at your design temps. Most likely a 1.5 ton will meet your needs.
Old 11-20-2011, 09:17 PM   #3
Rewards Points: 380
Are you working at heating or cooling? Where are you located?
HVACDave is offline   Reply With Quote
Old 11-21-2011, 04:42 AM   #4
Charleston SC
Old 11-21-2011, 01:55 PM   #5
jkv
tells you that a 1.5 ton system will take care of your needs. Is your heat elec. or gas or somthing else?
jkv is offline   Reply With Quote
Old 11-21-2011, 03:03 PM   #6
Heat Pump with Elec BAck Up
May I be so bold as to ask how you interpet those numbers into 1.5 tons
Thank you for all your help
As I am Great at computers and programs...
not an HVAC Expert
Old 11-21-2011, 03:17 PM   #7
An old Tradesmen
In air conditioning. 12,000 BTUs equals 1 ton. A 1 ton heat pump is not made in a conventional split system. So the next size up is 1.5 tons. Next, even if a 1 ton was made. You need 10,174 BTUs of sensible capacity. A 1 ton would not be able to provide that, as a min of 20% of its capacity would go to latent capacity, which would leave you only 9,600 BTUs of sensible. So you need a 1.5 ton to meet your cooling load.
Old 11-21-2011, 03:26 PM   #8
Thank you
Brian
If you ever need any Building Inspector Questions Answered look me up
