Semi Finished Basment Exposed Ceiling - HVAC - DIY Chatroom Home Improvement Forum
Old 03-29-2013, 04:30 PM   #1
bryanp22's Avatar
Rewards Points: 294
Semi finished basment exposed ceiling
Hi,
We are finishing a couple walls in our basement and want to leave the basement ceiling exposed as the ceiling height would be 7 feet if closed in. We have some air returns in the joists with just sheets of I think aluminum nailed on joist to create the return path. What can I do to cleanup how that looks?
bryanp22 is offline   Reply With Quote
Old 03-29-2013, 05:10 PM   #2
An old Tradesmen
Rewards Points: 7,344
Its sheet metal panning. You can clean them with alcohol and then paint them.
Old 03-29-2013, 06:12 PM   #3
bryanp22's Avatar
Rewards Points: 294
It's more how it's uneven and just nailed down on the edges.
Old 03-29-2013, 06:21 PM   #4
An old Tradesmen
Remove and replace. You can use thermal pan in place of sheet metal.
Trying to connect 2 ceiling fans to 1 switch alberta86 Electrical 6 02-05-2013 05:08 PM
Installing Ceiling Fan Electrical Box (Old Construction) jtslue24 Electrical 7 09-16-2012 12:58 PM
Mounting a ceiling fan on an exposed pergola Hoover98 Electrical 17 07-21-2012 10:05 AM
Running exposed romex along ceiling in garage Shrute Electrical 24 04-15-2010 09:11 PM
Ceiling condensation icemand Building & Construction 1 12-15-2009 05:16 AM
