Selecting Furnace - A Few Questions - HVAC - DIY Chatroom Home Improvement Forum
Old 08-02-2012, 02:47 AM   #1
Rewards Points: 29
Selecting furnace - a few questions
First of all, where does one buy a furnace? I have a Grainger near me that sells Dayton and Comfort-Aire...do I have to go through a middleman to get any of the other brands? Or is there a place I can just order one?
Secondly, I don't have the flue space for a metal venting furnace, so it has to be a PVC. So, for example, this furnace here:
http://www.grainger.com/Grainger/DAY...YT1?Pid=search
There is info about the venting size (2" to 3" depending on the run) but nothing about the venting type. How to know for sure?
BTW - has anyone ever ordered from zorotools.com? That same model is significantly less over there...
http://www.zorotools.com/g/00012390/...ign=shopzilla.
Thanks!
lmorsino is offline   Reply With Quote
Old 08-02-2012, 06:16 AM   #2
HVAC Contractor
Rewards Points: 336
You generally buy a furnace through a licensed contractor, who will install it safely and correctly for you
Seriously, if you're not even sure what type of vent to use, and you're selecting your furnace based on the amount of space you have for the vent, I'd serioulsy reconsider making this a DIY project. 95+ furnaces can be tricky to install and setup correctly, and an improper installation can have deadly consequences.
FYI: All 90+ furnaces vent with standard DWV PVC pipe. The vent must be installed according to code, and in many areas codes would not allow you to self-install a furnace.
scottmcd9999 is offline   Reply With Quote
The Following 2 Users Say Thank You to scottmcd9999 For This Useful Post:
ben's plumbing (08-02-2012), hvactech126 (08-02-2012)
Old 08-02-2012, 06:59 PM   #3
Rewards Points: 582
agree with scott....not a diy project.....get a licensed contractor to install it.
Furnace Interlocking for HRV mk5tdi HVAC 6 11-24-2013 08:19 PM
Some questions regarding furnace replacement Allears HVAC 3 05-27-2012 02:26 AM
Comparing and selecting a furnace installer Liberator HVAC 16 01-25-2012 02:49 PM
Oil Furnace Questions mudpaws HVAC 8 12-29-2010 02:29 PM
Draining furnace, couple questions. RyanD Plumbing 12 06-27-2009 08:42 AM
