Seer Rating???? - HVAC - DIY Chatroom Home Improvement Forum
Old 05-11-2009, 08:52 PM   #1
Seer rating????
My contractor says he installed a 16.5 seer system on my house but the outside unit says 13 seer. He states that with the coil in the atticit will be what he sold me, is this correct
dale
DDAVIS9009 is offline   Reply With Quote
Old 05-11-2009, 09:21 PM   #2
HVAC / Plumbing
he installed a evap. coil on a 13 seer condenser & now you have a 16.5 seer system ?
kenmac is offline   Reply With Quote
Old 05-11-2009, 09:53 PM   #3
Home Air Direct's Avatar
The Carrier guys have always talked about the "N" coil raising the SEER level, but I think you have been BS'ed. A larger evap coil and a TXV valve can maximize efficiency, but it is rare to see more than a single full point rise in SEER.
This is my experience, if others have info that I don't have, I would be interested too.
Settle down! If you were that important, the city would give you lights and a siren for your car
Home Air Direct is offline   Reply With Quote
Old 05-11-2009, 10:48 PM   #4
He said with the unit and coil combination it would be a 16 seer or 16.5 system
Old 05-11-2009, 11:11 PM   #5
This is the largest increase I can find with my equipment. This is the norm. I still think you have been had.
3 Ton 13 SEER R22 AC Whirlpool W2GC336A
4 Ton Variable Speed Air Handler WMB48VC
3.5 Ton "A" Coil WE(U,C,H,M)1P43C
SEER 14.0 EER12.00 ARI BTU Rated Capacity 35,000 CFM 1200 TXV A2TXV01
To check out the validity of your contractor's claims, check your model numbers with this website. http://www.ceedirectory.org/ceedirec...earchMain.aspx
Good Luck
Old 05-12-2009, 05:34 AM   #6
An old Tradesmen
Rewards Points: 7,344
Write down your model numbers of your outdor unit, indoor coil, or air handler.
And go the the AHRI website. And see what SEER it is rated at.
Also, your contractor should be able to show youo the tech guide SEER listing of the combination he installed.
If he doesn't have a guide, and you can't find a listing for it on AHR, then he is probably making the SEER rating up.
Old 05-12-2009, 08:13 AM   #7
Agreed with all of the above: can't think of any coil match that will take you from 13 to 16.5 SEER; and check the AHRI website for you system.
Or post you system here and we can check.
dac122 is offline   Reply With Quote
Old 05-12-2009, 09:40 AM   #8
Model # UANL-030JAZ made by Ruud
Evap coil : CE30D44-175L-028
This is a R-410a system
Old 05-12-2009, 10:13 AM   #9
Not sure if you have the right evap coil model number but here are all possible matches for your RUUD outdoor unit. Sorry for the formatting, but bottom line the max is 14.5 SEER. If you don't have a matching coil then I doubt you are better than 13 SEER.
I think it is time you ask for documentation showing 16.5 SEER
Code:
ARI #	OD Model#	ID Coil Model#	SEER
3169576	UANL-030JAZ	17AHLL36HM+RCSL-H*3617A*	14
3169577	UANL-030JAZ	17AHSL36HM+RCSL-H*3617A*	13
3169578	UANL-030JAZ	RBHP-21+RCHL-36A1	14
3169570	UANL-030JAZ	RCFL-A*3617B*	13
3169582	UANL-030JAZ	RCFL-A*3617B*	14
3169600	UANL-030JAZ	RCFL-A*3617B*	14
3169609	UANL-030JAZ	RCFL-A*3617B*	14
3169588	UANL-030JAZ	RCFL-A*3617B*	14
3337268	UANL-030JAZ	RCFL-A*3617C*	14
3337262	UANL-030JAZ	RCFL-A*3617C*	14
3337274	UANL-030JAZ	RCFL-A*3617C*	14
3337258	UANL-030JAZ	RCFL-A*3617C*	14
3337254	UANL-030JAZ	RCFL-A*3617C*	13
3169571	UANL-030JAZ	RCFL-A*3621B*	13
3169605	UANL-030JAZ	RCFL-A*3621B*	14.5
3169610	UANL-030JAZ	RCFL-A*3621B*	14
3169583	UANL-030JAZ	RCFL-A*3621B*	14
3169601	UANL-030JAZ	RCFL-A*3621B*	14
3169589	UANL-030JAZ	RCFL-A*3621B*	14
3169615	UANL-030JAZ	RCFL-A*3621B*	14.5
3337269	UANL-030JAZ	RCFL-A*3621C*	14
3337272	UANL-030JAZ	RCFL-A*3621C*	14.5
3337259	UANL-030JAZ	RCFL-A*3621C*	14
3337263	UANL-030JAZ	RCFL-A*3621C*	14
3337255	UANL-030JAZ	RCFL-A*3621C*	13
3337275	UANL-030JAZ	RCFL-A*3621C*	14
3337278	UANL-030JAZ	RCFL-A*3621C*	14.5
3169572	UANL-030JAZ	RCFL-H*3617A*	13
3169590	UANL-030JAZ	RCFL-H*3617A*	14
3169611	UANL-030JAZ	RCFL-H*3617A*	14
3169584	UANL-030JAZ	RCFL-H*3617A*	14
3169602	UANL-030JAZ	RCFL-H*3617A*	14
3169594	UANL-030JAZ	RCFL-H*3617A*	14
3337260	UANL-030JAZ	RCFL-H*3617C*	14
3337264	UANL-030JAZ	RCFL-H*3617C*	14
3337256	UANL-030JAZ	RCFL-H*3617C*	13
3337276	UANL-030JAZ	RCFL-H*3617C*	14
3337266	UANL-030JAZ	RCFL-H*3617C*	14
3337270	UANL-030JAZ	RCFL-H*3617C*	14
3169591	UANL-030JAZ	RCFL-H*3621A*	14
3169603	UANL-030JAZ	RCFL-H*3621A*	14
3169573	UANL-030JAZ	RCFL-H*3621A*	13
3169606	UANL-030JAZ	RCFL-H*3621A*	14.5
3169612	UANL-030JAZ	RCFL-H*3621A*	14
3169585	UANL-030JAZ	RCFL-H*3621A*	14
3169595	UANL-030JAZ	RCFL-H*3621A*	14
3169616	UANL-030JAZ	RCFL-H*3621A*	14.5
3337271	UANL-030JAZ	RCFL-H*3621C*	14
3337279	UANL-030JAZ	RCFL-H*3621C*	14.5
3337267	UANL-030JAZ	RCFL-H*3621C*	14
3337261	UANL-030JAZ	RCFL-H*3621C*	14
3337273	UANL-030JAZ	RCFL-H*3621C*	14.5
3337257	UANL-030JAZ	RCFL-H*3621C*	13
3337277	UANL-030JAZ	RCFL-H*3621C*	14
3337265	UANL-030JAZ	RCFL-H*3621C*	14
3169596	UANL-030JAZ	RCHL-36A1	13
3169580	UANL-030JAZ	RCHL-36A1	13
3169607	UANL-030JAZ	RCHL-36A1	13
3169586	UANL-030JAZ	RCHL-36A1	13
3169598	UANL-030JAZ	RCHL-36A1	13
3169617	UANL-030JAZ	RCHL-36A1	14
3169604	UANL-030JAZ	RCHL-36A1	14
3169613	UANL-030JAZ	RCHL-36A1	13
3169593	UANL-030JAZ	RCHL-36A1	13
3169592	UANL-030JAZ	RCHL-36A1	13
3169618	UANL-030JAZ	RCQD-3621A*	14.5
3169599	UANL-030JAZ	RCQD-3621A*	14
3169608	UANL-030JAZ	RCQD-3621A*	14
3169597	UANL-030JAZ	RCQD-3621A*	14
3169574	UANL-030JAZ	RCQD-3621A*	13
3169581	UANL-030JAZ	RCQD-3621A*	13.5
3169587	UANL-030JAZ	RCQD-3621A*	14
3169614	UANL-030JAZ	RCQD-3621A*	14
3169575	UANL-030JAZ	RCQD-3624A*	13
3169619	UANL-030JAZ	RCQD-3624A*	14.5
3169620	UANL-030JAZ	RHKL-HM3617+RCSL-H*3617A*	14
3337280	UANL-030JAZ	RHKL-HM3617+RCSL-H*3617C*	14
3169622	UANL-030JAZ	RHLL-HM3617+RCSL-H*3617A*	14
3337281	UANL-030JAZ	RHLL-HM3617+RCSL-H*3617C*	14
3169624	UANL-030JAZ	RHSL-HM3017+RCSL-H*3617A*	13
3337282	UANL-030JAZ	RHSL-HM3017+RCSL-H*3617C*	13
3169579	UANL-030JAZ	UBHP-21+RCHL-36A1	14
3169621	UANL-030JAZ	UHKL-HM3617+RCSL-H*3617A*	14
3169623	UANL-030JAZ	UHLL-HM3617+RCSL-H*3617A*	14
3169625	UANL-030JAZ	UHSL-HM3017+RCSL-H*3617A*	13
Old 05-12-2009, 11:32 AM   #10
Thank you
Thank you to everyone for their information and help. It takes a load off my mind...
Dale
Compressor cfm rating required for framing nailer tmeehan Tools 8 05-01-2009 11:17 AM
Receptacle Rating question Ultrarunner2017 Electrical 19 12-20-2008 06:20 PM
Receptacle Rating question Ultrarunner2017 Electrical 5 12-18-2008 05:36 PM
Whats the SEER rating? integlikewhoa HVAC 1 03-31-2008 11:08 PM
How do panels get their amperage rating? Randell Tarin Electrical 14 01-23-2008 06:10 PM
