-   -   Seer rating???? (http://www.diychatroom.com/f17/seer-rating-44316/)
DDAVIS9009 05-11-2009 08:52 PM
Seer rating????
My contractor says he installed a 16.5 seer system on my house but the outside unit says 13 seer. He states that with the coil in the atticit will be what he sold me, is this correct
dale
kenmac 05-11-2009 09:21 PM
he installed a evap. coil on a 13 seer condenser & now you have a 16.5 seer system ?
Home Air Direct 05-11-2009 09:53 PM
The Carrier guys have always talked about the "N" coil raising the SEER level, but I think you have been BS'ed. A larger evap coil and a TXV valve can maximize efficiency, but it is rare to see more than a single full point rise in SEER.
This is my experience, if others have info that I don't have, I would be interested too.
DDAVIS9009 05-11-2009 10:48 PM
He said with the unit and coil combination it would be a 16 seer or 16.5 system
Home Air Direct 05-11-2009 11:11 PM
This is the largest increase I can find with my equipment. This is the norm. I still think you have been had.
3 Ton 13 SEER R22 AC Whirlpool W2GC336A
4 Ton Variable Speed Air Handler WMB48VC
3.5 Ton "A" Coil WE(U,C,H,M)1P43C
SEER 14.0 EER12.00 ARI BTU Rated Capacity 35,000 CFM 1200 TXV A2TXV01
To check out the validity of your contractor's claims, check your model numbers with this website. http://www.ceedirectory.org/ceedirec...earchMain.aspx
Good Luck
beenthere 05-12-2009 05:34 AM
Write down your model numbers of your outdor unit, indoor coil, or air handler.
And go the the AHRI website. And see what SEER it is rated at.
Also, your contractor should be able to show youo the tech guide SEER listing of the combination he installed.
If he doesn't have a guide, and you can't find a listing for it on AHR, then he is probably making the SEER rating up.
dac122 05-12-2009 08:13 AM
Agreed with all of the above: can't think of any coil match that will take you from 13 to 16.5 SEER; and check the AHRI website for you system.
Or post you system here and we can check.
DDAVIS9009 05-12-2009 09:40 AM
Model # UANL-030JAZ made by Ruud
Evap coil : CE30D44-175L-028
This is a R-410a system
dac122 05-12-2009 10:13 AM
Not sure if you have the right evap coil model number but here are all possible matches for your RUUD outdoor unit. Sorry for the formatting, but bottom line the max is 14.5 SEER. If you don't have a matching coil then I doubt you are better than 13 SEER.
I think it is time you ask for documentation showing 16.5 SEER
Code:
ARI #        OD Model#        ID Coil Model#        SEER
3169576        UANL-030JAZ        17AHLL36HM+RCSL-H*3617A*        14
3169577        UANL-030JAZ        17AHSL36HM+RCSL-H*3617A*        13
3169578        UANL-030JAZ        RBHP-21+RCHL-36A1        14
3169570        UANL-030JAZ        RCFL-A*3617B*        13
3169582        UANL-030JAZ        RCFL-A*3617B*        14
3169600        UANL-030JAZ        RCFL-A*3617B*        14
3169609        UANL-030JAZ        RCFL-A*3617B*        14
3169588        UANL-030JAZ        RCFL-A*3617B*        14
3337268        UANL-030JAZ        RCFL-A*3617C*        14
3337262        UANL-030JAZ        RCFL-A*3617C*        14
3337274        UANL-030JAZ        RCFL-A*3617C*        14
3337258        UANL-030JAZ        RCFL-A*3617C*        14
3337254        UANL-030JAZ        RCFL-A*3617C*        13
3169571        UANL-030JAZ        RCFL-A*3621B*        13
3169605        UANL-030JAZ        RCFL-A*3621B*        14.5
3169610        UANL-030JAZ        RCFL-A*3621B*        14
3169583        UANL-030JAZ        RCFL-A*3621B*        14
3169601        UANL-030JAZ        RCFL-A*3621B*        14
3169589        UANL-030JAZ        RCFL-A*3621B*        14
3169615        UANL-030JAZ        RCFL-A*3621B*        14.5
3337269        UANL-030JAZ        RCFL-A*3621C*        14
3337272        UANL-030JAZ        RCFL-A*3621C*        14.5
3337259        UANL-030JAZ        RCFL-A*3621C*        14
3337263        UANL-030JAZ        RCFL-A*3621C*        14
3337255        UANL-030JAZ        RCFL-A*3621C*        13
3337275        UANL-030JAZ        RCFL-A*3621C*        14
3337278        UANL-030JAZ        RCFL-A*3621C*        14.5
3169572        UANL-030JAZ        RCFL-H*3617A*        13
3169590        UANL-030JAZ        RCFL-H*3617A*        14
3169611        UANL-030JAZ        RCFL-H*3617A*        14
3169584        UANL-030JAZ        RCFL-H*3617A*        14
3169602        UANL-030JAZ        RCFL-H*3617A*        14
3169594        UANL-030JAZ        RCFL-H*3617A*        14
3337260        UANL-030JAZ        RCFL-H*3617C*        14
3337264        UANL-030JAZ        RCFL-H*3617C*        14
3337256        UANL-030JAZ        RCFL-H*3617C*        13
3337276        UANL-030JAZ        RCFL-H*3617C*        14
3337266        UANL-030JAZ        RCFL-H*3617C*        14
3337270        UANL-030JAZ        RCFL-H*3617C*        14
3169591        UANL-030JAZ        RCFL-H*3621A*        14
3169603        UANL-030JAZ        RCFL-H*3621A*        14
3169573        UANL-030JAZ        RCFL-H*3621A*        13
3169606        UANL-030JAZ        RCFL-H*3621A*        14.5
3169612        UANL-030JAZ        RCFL-H*3621A*        14
3169585        UANL-030JAZ        RCFL-H*3621A*        14
3169595        UANL-030JAZ        RCFL-H*3621A*        14
3169616        UANL-030JAZ        RCFL-H*3621A*        14.5
3337271        UANL-030JAZ        RCFL-H*3621C*        14
3337279        UANL-030JAZ        RCFL-H*3621C*        14.5
3337267        UANL-030JAZ        RCFL-H*3621C*        14
3337261        UANL-030JAZ        RCFL-H*3621C*        14
3337273        UANL-030JAZ        RCFL-H*3621C*        14.5
3337257        UANL-030JAZ        RCFL-H*3621C*        13
3337277        UANL-030JAZ        RCFL-H*3621C*        14
3337265        UANL-030JAZ        RCFL-H*3621C*        14
3169596        UANL-030JAZ        RCHL-36A1        13
3169580        UANL-030JAZ        RCHL-36A1        13
3169607        UANL-030JAZ        RCHL-36A1        13
3169586        UANL-030JAZ        RCHL-36A1        13
3169598        UANL-030JAZ        RCHL-36A1        13
3169617        UANL-030JAZ        RCHL-36A1        14
3169604        UANL-030JAZ        RCHL-36A1        14
3169613        UANL-030JAZ        RCHL-36A1        13
3169593        UANL-030JAZ        RCHL-36A1        13
3169592        UANL-030JAZ        RCHL-36A1        13
3169618        UANL-030JAZ        RCQD-3621A*        14.5
3169599        UANL-030JAZ        RCQD-3621A*        14
3169608        UANL-030JAZ        RCQD-3621A*        14
3169597        UANL-030JAZ        RCQD-3621A*        14
3169574        UANL-030JAZ        RCQD-3621A*        13
3169581        UANL-030JAZ        RCQD-3621A*        13.5
3169587        UANL-030JAZ        RCQD-3621A*        14
3169614        UANL-030JAZ        RCQD-3621A*        14
3169575        UANL-030JAZ        RCQD-3624A*        13
3169619        UANL-030JAZ        RCQD-3624A*        14.5
3169620        UANL-030JAZ        RHKL-HM3617+RCSL-H*3617A*        14
3337280        UANL-030JAZ        RHKL-HM3617+RCSL-H*3617C*        14
3169622        UANL-030JAZ        RHLL-HM3617+RCSL-H*3617A*        14
3337281        UANL-030JAZ        RHLL-HM3617+RCSL-H*3617C*        14
3169624        UANL-030JAZ        RHSL-HM3017+RCSL-H*3617A*        13
3337282        UANL-030JAZ        RHSL-HM3017+RCSL-H*3617C*        13
3169579        UANL-030JAZ        UBHP-21+RCHL-36A1        14
3169621        UANL-030JAZ        UHKL-HM3617+RCSL-H*3617A*        14
3169623        UANL-030JAZ        UHLL-HM3617+RCSL-H*3617A*        14
3169625        UANL-030JAZ        UHSL-HM3017+RCSL-H*3617A*        13
DDAVIS9009 05-12-2009 11:32 AM
Thank you
:thumbsup:Thank you to everyone for their information and help. It takes a load off my mind...
Dale
