In brief:
Our furnace stopped putting out hot air on Saturday and an HVAC specialist from the company the warranty people uses came out this morning, Monday. I was unhappy because he didn't examine the furnace thoroughly and was short with me when I asked for an explanation. The more detailed version below... Thank you in advance if you read this and especially if you share your opinion as to whether the specialist did the right thing or I'm just too ignorant of furnace function to have an opinion at all
In not so brief:
The furnace (Carrier 58MXA) began blowing out cold air so my husband reset it as per furnace manual instructions. It went through a test sequence and then the LED panel began saying "Ignition Lock Out". This would indicate an issue with the ignition mechanism (no pilot light on this furnace). The furnace was still blowing cold air so we turned it off.
This morning the HVAC specialist arrived and as soon as I had left the room he called me back. He told me a widget in the furnace was located in the body of the furnace instead of underneath, and that this was a fire hazard that had caused several fires, mostly in the West. He would have to order a kit to replace it. At this point I realized the furnace was going and I asked if he'd found an issue; he said he had only reset it. Of course after HE reset it it started blowing hot air.
So I told him I was grateful he'd realized it had an issue but was he not now going to look at the ignition to figure out what had caused the original issue? He said no he didn't have to since it was probably related to the widget that had to be moved. I said I would appreciate if he could please look at the ignition since the furnace's test sequence indicated there was a problem there and this recalled widget had been there all along not causing heating problems. He said the same thing again. I asked if this was company policy and he said no it was his policy. Then he began to flee from my home, and on his way out I told him that when you take a car to get repaired they take care of necessary recalls but they still try to diagnose the problem that you brought it in for. His response as he walked out the door was, "I've been doing this for 12 years, just trust me".
Now one of my peeves is people that don't take the time to explain things thoroughly to me. I don't expect to understand as well as an expert in whatever field obviously but whether it's my optometrist or dentist or HVAC specialist I appreciate an explanation and many in the past (including HVAC specialists) have been very gracious. This man looked sour from the get go and I immediately felt disappointed because I've noticed a direct correlation between how much people seem to enjoy their jobs and their performance of them. Also how willing they are to talk about their field to a non-expert.
So if you read my mammoth posting, thank you! Do you think I should ask that someone come to do a thorough examination of my furnace, particularly (presumably) the ignition? Or am I just ignorant of furnace innards and therefore also ignorant of the fact that moving the widget would fix any potential future losses of hot air? I have three very small boys and am pregnant with our fourth and don't want my heater going out in the middle of next winter because of a problem that could be spotted now. Thank you in advance for any insight.
