Seeking Advice On Replacing A/C - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-15-2013, 04:02 AM   #16
An old Tradesmen
Rewards Points: 8,168
Originally Posted by bobelectric View Post
Can you use the registers to balance air flow?
You can, but often you end up with air noise from them when you have to choke back a large amount of air.
Old 05-15-2013, 11:56 AM   #17
Thank you all for your sound advice. One sales rep showed us how the returns downstairs were sucking in a lot more air than the upstairs ones. Is it possible to block off a return downstairs to force more of the hot air to the upstairs returns?
g_money is offline   Reply With Quote
Old 05-15-2013, 01:14 PM   #18
Hvac Pro
yuri's Avatar
Rewards Points: 384
Not a good idea. If you do that and restrict the air to the furnace then the furnace may overheat and get damaged or the AC will freezeup and get damaged. Same thing can happen if you shut supply vents on the main floor to try push more air upstairs. This is where you need a really qualified tech to check the airflow/temps/freon pressures etc to make sure nothing is overheating or going to freezeup.
Old 05-15-2013, 04:11 PM   #19
An old Tradesmen
What he showed you is that your down stairs returns are under sized. Since you may have felt a lot more air movement, it isn't necessarily moving more air.
Seeking Advice (or Warnings) RE: this Table Saw . . . CaptainMarvel Tools 12 11-08-2014 08:18 AM
Seeking Advice.. HORRIBLE drainage problem :( NegativeTen Landscaping & Lawn Care 14 03-29-2013 09:26 PM
Seeking heating system retrofit advice patrick.ogrady HVAC 4 03-22-2013 05:32 PM
Seeking advice for wiring in hot-tub. YerDugliness Electrical 47 03-17-2012 11:35 PM
Need advice on replacing furnace with HVAC Joe Cass HVAC 5 02-15-2012 06:36 PM
