#1 |
A secure Room Thermostat
I need to replace our room thermostat with one that is tamper proof and preferably password protected. Is there such a thing as this?
People at my place keep removing the cover and rotating the spindle by hand to bypass the stop on the dial's rim. Thanks. |
#2 |
Eibwen
Try sti-usa.com
They make a wide range of locking covers just for that purpose. |
#3 |
They sure do.
Many thanks. |
#4 |
Eibwen
Your welcome
#5 |
Journeyman
As Sammy said you could go with a lock box, don't know of a t-stat that is password protected, there are several options. You could install a new t-stat with a remote sensor then you could move the t-stat anywhere you want. You could try an accustat, they work off of sensors that are set for a spec. temp. Or you could just fire they guy that keeps messing with it
then leave the stat where it is
#6 |
Chicago, IL
There are many password protected thermostats, any HVAC supply house stocks them. The ones I see most frequently in my are area are from White Rogers.
---------- Home Inspection: ""A business with illogically high liability, slim profit margins and limited economies of scale. An incredibly diverse, multi-disciplined consulting service, delivered under difficult in-field circumstances, before a hostile audience in an impossibly short time frame, requiring the production of an extraordinarily detailed technical report, almost instantly, without benefit of research facilities or resources." - Alan Carson |
#7 |
Hvac Pro
The Honeyell TH800 series Vision Pros are lockoutable. http://customer.honeywell.com/honeyw...px/TH8110U1003
http://customer.honeywell.com/Honeywell/UI/Pages/Catalog/AssemblyCategory.aspx?Catalog=Homes&Category=Visio nPRO%C2%AE_32693&ChannelID={2EB2F178-20ED-44E0-97FB-CCFB4218DD64}. You need to know if you have 2 stage heating/cooling. |
#8 |
An old Tradesmen
Use a tat with a remote sensor. And lock the stat in your office, or the mech room.
#9 |
Average Joe/ex-Navy IC3
Even easier, is to just purchase one that is set at a preset temp, so that there is not messing around. If the workers are removing the cover, time to rewrite the employ handbook, or talk to HR that this is something that needs to be discussed. Falls under the same rules as destruction of company property or Vandalism of same. You touch, you walk.
#10 |
Xtreme DIY'r
They had a locking one at a convenient store I worked at ages ago
The store was always cold & the cashiers would sit on the radiator to keep warm. I only worked there now & then when they needed extra help - I was an Asst Mgr at another store Winter came & it was freezing So I grabbed blue ice & put it around the thermostat One of the Reg employees came in & was amazed it was warm!! "They finally fixed the heat!!" Nope, I pointed to the blue ice After that the blue ice stayed all winter & was changed out as needed |
| Display Modes | |
| Thermostat VS Ceiling fan | MrShadetree0222 | HVAC | 38 | 01-23-2010 04:29 AM |
| Cold Room | mikelbeck | HVAC | 14 | 01-16-2009 09:21 PM |
| Raising Doorway Height (load bearing?) | treefrog | Building & Construction | 6 | 02-25-2008 10:11 PM |
| Heat pump in non insulated nor heated room | robdville | HVAC | 3 | 01-21-2008 03:51 PM |
