Second Story House Cooling Question. - HVAC - DIY Chatroom Home Improvement Forum
Old 08-07-2009, 03:07 PM   #1
Second Story house cooling question.
Okay I just bought this house and notice a difference in temperature between the 1st and 2nd floor.
Let me give some background. I live in Houston, TX so the humidity is high and temps can get to 102-104 every day. My two units outside are new (Goodman) Seer 13 4ton and seer 13 2.5ton. Downstairs cools perfectly. My house during the day does get hit with the sun all day.
I am use to 2nd story homes (like my last one) when I turn the temp to 75F on a hot day, it actually reaches 75. During a hot day upstairs can reach 86-87F. I have had the coils/air handler inspected/replaced one.
So my question is what would be the best way to cool off the top floor, or at least my big computer room.
1. Solar attic fan
2. Radiant barrier
3. Portable A/C and dehumidifier and turn on only when I am upstairs.
Any other suggestions? Thanks for your time.
darktiger is offline   Reply With Quote
Old 08-07-2009, 06:50 PM   #2
How big an area is the up stairs?
hvaclover is offline   Reply With Quote
Old 08-07-2009, 09:18 PM   #3
GC/Master Plumber/Mech
Rewards Points: 560
If this has an attic how much insulation is there?
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 08-07-2009, 11:39 PM   #4
1100sqft more or less. The attic is pretty insulated. A good 3" of yellow fiberglass that looks blown in...
Old 08-07-2009, 11:43 PM   #5
Rewards Points: 560
3 inch of insulation is about an R-12/13 you need to be in the area of R-38. About 12" of blown insulation would help. You would be suprised what another 9 or 10 inches will do.
1 inch of blown insulation equals approx R-3
Old 08-08-2009, 06:18 AM   #6
An old Tradesmen
Rewards Points: 6,060
Add radiant roof barrier, and get more insulation.
3" is a joke for an attic.
Old 08-08-2009, 08:35 AM   #7
I'm in the North & I have 12" of insulation = R38
More for heat retention in the winter
But without it the summer sun will bake the 2nd floor
If there are any soffit vents make sure you do not block them
Old 08-08-2009, 03:52 PM   #8
JohnH1's Avatar
4 Tons of cooling for 1100 sqft? Dosent that seem a little over kill guys. You should have no problem cooling but maby a problem controlling humidity due to short cycling. It sounds like you may have somthing not operating correctly. What is the temp drop from the return to the supply?
JohnH1 is offline   Reply With Quote
Old 08-08-2009, 05:33 PM   #9
An old Tradesmen
I don't see that he said the 4 ton unit does the 110 sq ft.
But, I do see that he says the outdoor units are new.
Taking that to mean they are mismatched to some old air handlers.
Which could be causing trouble.
Old 08-08-2009, 07:21 PM   #10
Rewards Points: 560
1. Solar attic fan
2. Radiant barrier
I take it as 4 tn downstairs and 2.5 upstairs
Old 08-08-2009, 08:14 PM   #11
He didn't say 110 sqft
Old 08-08-2009, 08:17 PM   #12
An old Tradesmen
Lol
Old 08-08-2009, 10:30 PM   #13
JohnH1's Avatar
I missed the period between (13 2.5ton).( Downstairs cools perfectly) I need to slow down my reading.
Connecting main house to guest house... hlavine Building & Construction 31 03-28-2012 10:04 AM
Whole house water filter question Davidb6 Plumbing 4 07-01-2009 10:36 PM
My new project, 31 year old house... Axhammer General DIY Discussions 3 04-08-2009 09:46 AM
Help... Trying to install can lights on the first floor of a two story house... whutitdew25 Electrical 5 03-17-2008 01:51 AM
Coaxial Cable Question bahaisamurai Home Theater 9 08-08-2007 03:54 PM
