Sears Homart Automatic Heating (furnace Probably From 60's) - HVAC - DIY Chatroom Home Improvement Forum
Old 04-15-2010, 01:36 AM   #1
Sears Homart Automatic heating (furnace probably from 60's)
I have a furnace that has been working fine. It proably isn't as efficientAS A MODERN ONE HOWEVER In the winter the gas bill is never higher than $60.00 per month (there is a pilot light and the house has gas oven/stove and gas dryer. Usually around $30,00 in cooler months, so repairing this is definitly an option. It has stopped. What can I problem solve? ELECTRIC MOTOR? OR? (gas polot is still on-maybe I'll change to pilotless electric ignition?) ANY suggestions welcome as soon as possible!!!!!
It's not the thermostat
Thank you
isaagold is offline   Reply With Quote
Old 04-19-2010, 01:38 PM   #2
sktn77a's Avatar
Rewards Points: 392
Unfortunately, and with all due respect, if you have to ask you probably are not is a position to mess with a gas furnace yourself. You need to pay the $100-or-so and have a reputable HVAC company come in and fix it for you.
sktn77a is offline   Reply With Quote
Old 04-19-2010, 10:30 PM   #3
An old Tradesmen
Rewards Points: 7,816
Do you have a thermocouple, or a thermopile?
Could be the gas valve.
Or perhaps a bad transformer.
Or a blown fuse.
Or someone turned off the emergency switch.
Tags
homart , old furnace , sears , stopped working
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
Homart (Sears) gas forced air, pilot won't stay lit. OLD TIMER NEEDED diyjohn HVAC 5 12-07-2011 09:15 PM
Ruud Electric Heating Furnace jacksadvantage HVAC 3 01-15-2010 04:56 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
