Sealing Off Air Vent - HVAC - DIY Chatroom Home Improvement Forum
Old 08-28-2007, 04:42 PM   #1
We have two extra vents with registers in our living room that we would like to seal off and put built-in bookcases over. Do we need place some kind of seal over the duct end itself, or is it OK to just remove the register and install wood flooring over the hole that is left. Any advice appreciated!
kbf99 is offline   Reply With Quote
Old 08-28-2007, 05:03 PM   #2
Why do you think these are "EXTRA" vents?
Big Bob is offline   Reply With Quote
Old 08-28-2007, 05:08 PM   #3
Answer
Our living room has a large number of vents all within a fairly close distance of each other, so it seems like we could close them off and not have any adverse consequences. Plus, we would like to use the space to build some built-in bookshelves. The vents are on either side of our fireplace, and we would like to put some bookshelves there.
Old 08-28-2007, 05:37 PM   #4
Most builders are not in the habit of adding unneeded ducts and vents.
If you haven't had your HVAC system serviced in a while do so and ask the tech about your plan.
or post a floor plan with elevation info and location of all your supply and return vents size and type of your HVAC system.
You most likely need the vents and relocation, build above, or integrate vents in your custom book shelf are your best options.
Old 08-28-2007, 05:46 PM   #5
Bob, good advice, and thanks
Old 08-28-2007, 10:32 PM   #6
Long-Time DIYer
Mike Swearingen's Avatar
kbf99,
Some of those vents may be part of your HVAC and some may be intake or blower vents from your fireplace box.
Can you see the ductwork from underneath to determine what is what? Basement or crawlspace?
Mike
Mike Swearingen is offline   Reply With Quote
AIR VENT SHINGLE VENT ll Docfletcher Roofing/Siding 8 06-04-2011 10:05 AM
loop vent or auto-vent amakarevic Plumbing 4 08-21-2007 01:28 PM
Yoke vent for water closet kenlog Plumbing 4 07-13-2007 07:34 PM
Bathroom Vent Not Vented to Outside / Would need to vent through flat roof House_Amuck HVAC 5 03-30-2007 10:57 AM
Ridge Vent - Low-pitched roof? brianp Roofing/Siding 2 05-08-2006 09:32 PM
