Old 10-27-2009, 12:50 AM   #1
DIY on the budget
diy-diy's Avatar
Question Sealing new blower for cold weather (foto)
New HVACs have been installed in my old apparent. Problem is the cold air coming from underneath (see photo) even then it switched off and it gets really bad when it's windy outside (wind blowing into the same window). I figure it needs to be removed (hope rather not) and its base sealed somehow. Can foam be used (what kind) or anything else (I don't want to damage device itself)? Other options. Any advise will be greatly appreciated...
diy-diy is offline   Reply With Quote
More On This Topic
Hi! My name is Joshua Lindsey with CFM Building Science Solutions. On behalf of Expert Village, we are doing a frame walk and insulation inspection on this home. In talking about insulation, one area that we need to cover is how well your house is sealed... Read More »
Your home's heating and air conditioning system (HVAC) is one of the most important elements involved in enjoying your home. Besides providing a comfortable environment, your HVAC also helps to maintain your health by protecting you from extreme... Read More »
Ice fishing is a popular pastime in the northern states where the lakes and rivers freeze. The ice fishing houses range in sophistication from a little pup tent to a fully built, functioning home. There are several ways to heat the ice fishing house... Read More »
How to Light a Bonfire
How to Light a Bonfire by Expert Village
All right, we're ready to start our fire. What I always like to have nearby is my blower, just in case it needs a little extra air and oxygen to get moving. I don't think its going to be an issue today since we've got a nice little bit of wind coming at... Read More »
When you’re dressing for whitewater canoeing you want to make sure you dress for the water temperature, not just for the air temperature. The air temperature can easily be 85 degrees out and the water temperature can be very cold because the water... Read More »
Furnace will not stay on allenzachary HVAC 30 10-21-2009 01:46 AM
Carrier 58MXA Wiring Blower Switch 63012753 HVAC 0 10-06-2009 11:09 PM
AC blower short cycling-works on heat though Steve60007 HVAC 14 06-22-2009 06:00 PM
replacing weather stripping on front door cao911 Remodeling 4 11-21-2008 07:50 AM
Heat comes on but blower never does aczer HVAC 11 11-21-2006 04:37 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
