Sealing/Insulating Furnace In Garage - HVAC - DIY Chatroom Home Improvement Forum
Old 09-28-2011, 09:22 PM   #1
Rewards Points: 152
Sealing/Insulating Furnace in Garage
I have an electric forced air furnace, located in my garage. Garage is insulated, but not heated.
The furnace used to have foil faced insulation on it, noticed it was extremely dusty when I bumped into it the other day. Also seems to be pretty dusty inside the house.
Couple questions...
1) Should I seal the joints with the proper foil tape? Or are these joints already airtight?
2) What should I use to replace the insulation on it? There's a gap between the sheet metal and the floor where it used to be stuffed underneath. Can I use rigid polystyrene or will it be too hot?
3) Where the ducting enters the ceiling, can see a bunch of batt insulation sort of sticking out (can sort of see it in the second picture). What would be a good way to seal that off? If I change the oil in a vehicle in the garage, we can smell it upstairs even if the furnace isn't on. Sort of thinking the fumes are travelling through there?
Thanks!
burnt03 is offline   Reply With Quote
Old 09-28-2011, 09:30 PM   #2
Rewards Points: 150
Furnaces should never be in garages because of co2. You should frame it into a closet then open it from the outside with an exterior door.
OhioHomeDoctor is offline   Reply With Quote
Old 09-28-2011, 09:43 PM   #3
Rewards Points: 152
Carbon Dioxide? Do you mean carbon monoxide if I were to leave the car idling in the garage?
Old 09-28-2011, 09:53 PM   #4
Rewards Points: 150
Sure carboncankillyoustuff2.
Old 09-30-2011, 06:06 AM   #5
the Musigician
DangerMouse's Avatar
What does this mean?
DM
Do I have a Fire Rating Issues with Attached Garage Perry401 Building & Construction 4 04-25-2011 11:58 PM
heating a room over the garage moisheh HVAC 1 02-10-2010 06:42 AM
Wiring a T-stat for my garage furnace. klapool HVAC 45 01-08-2009 03:47 PM
Garage ceiling and attic storage DIY KEN Building & Construction 7 01-06-2009 04:57 PM
garage furnace mrseebro HVAC 3 01-07-2008 07:25 AM
