Sealing Furnace Flu - HVAC - DIY Chatroom Home Improvement Forum
Old 11-13-2013, 08:06 PM   #1
Dave Sal's Avatar
Rewards Points: 574
Sealing furnace flu
Hey guys,
I recently went in my upper attic (tri-level home) and added an additional layer of R30 unfaced fiberglass insulation over the existing R30. While up there I noticed that there is a large gap, approximately 2"-3" at it's widest point where the furnace flue enters the attic. I think I need to go back up there and seal it before the winter sets in. Before I climb up there though, I checked the furnace room as well and saw that there is another huge gap where the flue goes up through the ceiling. (see pics).
My question is what is the proper method of sealing these openings? I know it can get pretty hot and fiberglass insulation is not supposed to be used. Would Great Stuff Fireblock foam work for this situation? If I seal the bottom opening above the furnace room is it necessary to do the same in the attic? I hate climbing up into the attic and have been up there twice in the last month. I'm getting too old for this stuff. Thanks
Sealing furnace flu-gap.jpg   Sealing furnace flu-img_2724.jpg   Sealing furnace flu-img_2725.jpg
Dave Sal is online now   Reply With Quote
Old 11-13-2013, 08:13 PM   #2
Rewards Points: 582
that looks caps for what was used and called ducttile that is a very tight fit to the pipe going up ...don't think you need to do anything with it ....ben sr
Old 11-13-2013, 09:45 PM   #3
Dave Sal's Avatar
Rewards Points: 574
Thanks for the reply Ben Sr. You are correct in that the flue seems to be installed properly with the duct tile or whatever it is called. The builder apparently got that right, but my concern is the large hole (the chase?) that is allowing conditioned air to flow up the hole into the attic. I know that fiberglass insulation is a no no and was thinking of maybe stuffing it with Roxul. I'm thinking I should have posted this in the insulation sub-forum.
Old 11-14-2013, 09:53 AM   #4
Rewards Points: 154
flash it with metal and fire caulk it if it worries you.
Patrick Eubanks is offline   Reply With Quote
Oil Furnace Emergency shut off switch location? LarryNH914 HVAC 19 06-28-2012 03:47 PM
Furnace Model # Feh-015-04 clicking but not turning on? haimei HVAC 1 12-14-2010 06:01 PM
Payne PG9YAB high efficiency 95% furnace water draining problem jchen64 HVAC 9 12-06-2010 07:42 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 07:43 PM
Problem with Trane gas furnace quovadis HVAC 17 12-22-2008 02:12 PM
