Sealing Ductwork - HVAC - DIY Chatroom Home Improvement Forum
Old 06-29-2009, 10:45 AM   #1
Sealing Ductwork
I am installing new ductwork in my home, currently there is no A/C and the heat is hot water radiators. I am using mastic and UL rated foil tape to seal all the joints and connections. My question is, can I apply the foil tape to the inside of the duct? In other words, since this is all new equipment, I have access to the inside of the ductwork. I found it easier to apply the mastic to the inside and outside of the connection, but the foil tape is much easier to apply to the inside. I get smoother seams and the connection is better. My concern is that in the future, if the foil tape fails, will I hear flapping?
Thank you
Larry Leso is offline   Reply With Quote
Old 06-29-2009, 04:19 PM   #2
sktn77a's Avatar
Rewards Points: 392
Well, the constant airflow by the tape may pull any exposed edges up and then off the inside. I can't envision how it's easier to apply the tape on the inside than the outside, without reaching up inside the ductwork (?)
sktn77a is offline   Reply With Quote
Old 06-29-2009, 04:55 PM   #3
It's easier on the inside because I'm using rectangular duct. The duct comes in halves, so before I assemble the two halves to get my final rectangular trunk line, I measure, cut the openings for and install the boots for the takeoffs. That is what I'm taping.
I didn't mean to confuse you, after I have all the boots placed, I then assemble the halves of the rectangular duct and when I connect the other fittings, I tape the outside seams. It's just the initial takeoff boots that I am taping on the inside.
Old 06-29-2009, 06:27 PM   #4
sktn77a's Avatar
Rewards Points: 392
Ah, OK, that makes more sense.
Tags
duct , foil tape , hvac installation
need help with package unit ductwork bekind42 HVAC 15 11-04-2011 04:13 AM
Help moving ductwork in order to finish my basement Rhat HVAC 7 06-15-2009 09:57 AM
Sealing windows with vinyl siding bighoneydolist Building & Construction 8 03-08-2009 07:36 PM
Ductwork on a SOUTH DAKOTA remodel asorenso General DIY Discussions 1 02-11-2009 06:55 AM
Basement Bypass door under ductwork Boomer313 Building & Construction 4 12-11-2008 09:17 PM
