Sealing Attic Furnace Room - HVAC - DIY Chatroom Home Improvement Forum
Old 04-10-2013, 10:34 AM   #1
Rewards Points: 324
Sealing attic furnace room
Hello and I apologize if this was discussed previously. We have our second furnace in the attic space that the builder had built a room around for energy efficiency. It's fully insulated with drywall. The high efficiency dual stage furnace has both intake and exhaust going to the outside through the roof.
I am reading that mechanical rooms with water heater needs additional vent to ensure it gets adequate air for combustion. Does this rule apply to me if I don't have water heater in the attic furnace room?
Thanks!
sbkim is offline   Reply With Quote
Old 04-10-2013, 11:22 AM   #2
Rewards Points: 744
You just said the furnace has both intake and exhaust going through the roof and that there's no water heater in there. So, what the problem?
Seattle2k is offline   Reply With Quote
Old 04-10-2013, 11:32 AM   #3
Rewards Points: 324
Thanks for the reply! Perhaps it's paranoia of reading various posts on this and other forums and my misunderstanding about having adequate combustion air in addition to the air intake from outside.... The room which is sealed with a non louvered door is about 10' x 10' x 7' The BTU of the furnace is 100,000. No other equipment exists. I guess what I am hearing is that I don't need additional vents to let air in from rest of the attic?
This was the article I was reading about having adequate space for combustion which may not apply to me since I have direct vent?
http://staff.jccc.edu/jbennett/curre...ng/COMBUST.htm
Old 04-10-2013, 10:00 PM   #4
Rewards Points: 446
You're correct, you don't need combustion air in the room if the furnace is rated as sealed combustion and installed correctly to meet that specification.
old_squid is offline   Reply With Quote
Old 04-11-2013, 05:03 AM   #5
An old Tradesmen
Rewards Points: 7,270
As long as your furnace has its own combustion air intake as you described. The room doesn't require any additional air intake. The link you posted to would apply if your furnace got its combustion air from the room.
Old 04-11-2013, 08:29 AM   #6
Rewards Points: 324
Thanks so much! I guess I got confused with set up in my basement which had water heaters that my inspector required vents be installed.
Nordyne furnace, error code: Pressure switch stuck closed. javagrendel HVAC 21 03-25-2013 01:14 PM
Ideas for retrofitting baffles/insulation in vaulted ceiling of built out attic room rachelsue20 Insulation 5 04-28-2012 07:49 PM
Quote for new furnace. Reasonable? dengle HVAC 16 03-04-2012 07:01 AM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
Gas furnace in SPF sealed attic dmcmillen HVAC 4 06-27-2009 08:39 PM
