Sealing Around Wood - HVAC - DIY Chatroom Home Improvement Forum
Old 07-07-2008, 11:05 AM   #1
sealing around wood
I installed a portable AC with the exhaust going out a balcony door.
The plastic window kit for the exhaust didn't extend high enough so I used a piece of wood.
I am having trouble sealing around the wood.
I tried duct tape, masking tape, weather stripping tape but nothing sticks to the wood for very long. :-(
I am thinking of painting the wood for next summer (I don't want to take it out for long this summer).
I considered silicone but I don't think that will come off easily (I am in an apartment).
jammer99 is offline   Reply With Quote
Old 07-07-2008, 11:08 AM   #2
why not go to home depot and buy some sort of metal transition you can screw to the wood instead and then screw your ductwork tot he transition?...Might cost you all of $5, if I understand your post properly.
statman is offline   Reply With Quote
Old 07-07-2008, 11:20 AM   #3
I hope this picture is good.
The part I need to seal it around the wood and the door.
|W||D
|W||D
|W||D
|P||D
|P||D
W is wood
P is plastic
D is the sliding door
the wall is to the left
the exhaust hose goes through the plastic at the bottom
Old 07-07-2008, 03:46 PM   #4
Rewards Points: 150
ghettorific
take a garbage bag and pull it tight around the wood and staple it off (or tape it to itself ) then any tape you want will stick . I just saved you 5 bucks
geo fan is offline   Reply With Quote
Old 07-07-2008, 03:51 PM   #5
Awesome idea.
Maybe I could have done without the wood.
Brick and wood flooring jhughesfam Flooring 1 08-18-2007 04:29 PM
Wood close to Non-IC recessed lighting-solution? sjmonty Electrical 4 12-01-2006 10:14 AM
sealing wood farrington135 Carpentry 1 10-18-2006 08:26 PM
Wood to Concrete without Drilling MattStata Carpentry 1 04-19-2006 05:16 PM
