Sealing Air Return Duct - HVAC - DIY Chatroom Home Improvement Forum
Old 09-27-2010, 02:35 PM   #1
Sealing air return duct
Hi guys, new member here. I've done my share of projects around the house, but never done any HVAC work before, so please bear with me.
I'm trying to seal the return air duct on my furnace (non-condensing, down draft). The return duct is made of galvanized sheet metal (rectangular - 24" x 10" x approx. 15ft length) and it's anchored to the garage ceiling with straps). The duct transitions to a joist cavity in the ceiling (that seal is also very poor). To properly seal the duct it, I might to have to remove it from the ceiling, although I'd very much like to avoid that - the thing probably weighs 150lbs+.
My questions to you are:
- How much can I twist/bend this duct without breaking it? The backup plan would be to seal it "in place" - remove some of the anchors (while supporting the duct), twist the duct a bit (to distance it from the wall/ceiling) and apply mastic or tape.
- What should I be using to make a good transition to the joist space? Right now there's just a hole in the top of the duct and another hole in the drywall. I'm thinking something like a collar would help? (then seal it with foam or tape/mastic).
Thanks in advance!
jd1979 is offline   Reply With Quote
Old 09-27-2010, 10:57 PM   #2
Bump.
Old 09-29-2010, 10:35 AM   #3
There are a variety of tapes and sealing compounds available. Go to Lowe's (or your local HVAC supply if they'll let you) get a roll of UL approved tape (181 A/B) a gallon of duct seal and a brush. Go to town, but be careful removing hanging straps.
brandonmcginnis is offline   Reply With Quote
Old 09-29-2010, 06:11 PM   #4
Thanks! How do I make the proper transition from the galvanized duct to the joist space? Whoever built the system left a 1/2 inch gap between the hole in the ceiling (leading to the joist cavity) and the duct. Is there a specific connector i should be using?
Old 10-05-2010, 12:42 AM   #5
I wouldn't even bother with this. I believe the more air that goes in the furnace, the better. If it's like most systems, there probably isn't enough return air to begin with. The installer left that half inch gap for even more airflow. Someone correct me if this is wrong, but I think that's how it goes. Always remember that you need as much air coming in to your furnace, as you need coming out.
jasonj is offline   Reply With Quote
Old 10-05-2010, 07:14 AM   #6
steveel's Avatar
What climate is this in, where is the furnace located, is the garage heated, and where is that wall cavity in relation to hot/cold sides of the system?
steveel is offline   Reply With Quote
Old 10-06-2010, 01:26 AM   #7
The furnace is in the garage, so if there's a gap in the return duct, air from the garage would be sucked into the house.
Old 10-06-2010, 05:18 AM   #8
An old Tradesmen
Rewards Points: 6,548
Not suppose to be any air transfer from a garage to a return duct. The code for several years now, requires the duct to be enclosed if its in a garage to prevent garage air from being drawn into the duct system.
Old 10-07-2010, 08:46 PM   #9
Right I never realized it was in the garage! You wouldn't want to suck up car fumes that's for sure! Thanks.
Tags
air , hvac , leak , return , seal
Cold Air Return next to supply duct thebigbbm HVAC 6 09-21-2010 06:51 PM
HELP old apartment .. Return Duct / Heat pump thethrowdown HVAC 1 01-29-2010 04:36 PM
question on return duct familyman HVAC 13 01-25-2009 12:05 PM
Return duct "boot or no boot" ads67 HVAC 16 01-10-2009 10:38 AM
Duct sealing and balancing harley101 HVAC 5 11-13-2008 08:44 PM
