I live in Alaska and am planning to replace my current furnace and hot water heater thru a weatherization program but am getting nervous as I have not yet heard any good things about dealing with sealed combusiton units. I have ordered a Lennox G71MPP 95 percent efficient furnace and decided to go with a tank/sealed combustion 40 gallon hot water heater rather than tankless. I will then be able to sealed off the crawlspace (where both have been and will be installed). Venting will be thru the roof rather than thru the side of the house. After adding insulation to the crawlspace, I should be able to get the entire project paid for thru rebates or very close to it anyhow. I am nervous about having maintenance problems with furnace and/or hot water heater but the reputable installer sees this as regular annual maintenance only. I would not be doing any of the work except the crawlspace upgrades.
Any input would be much appreciated. The troubles I have heard about from others have to do with venting. I have heard of problems with the systems vented out the side of the house AND problems with venting out the top.
