Seal Space Between Furnace And Flue Exit? - HVAC - DIY Chatroom Home Improvement Forum
Old 12-21-2010, 11:41 AM   #1
Question
Seal Space Between Furnace and Flue Exit?
Quick question: I have a Trane XR80 in the attic, horizontal. Flue pipe comes out of one end of the furnace, goes a few feet to elbow, and up to roof.
Between the furnace and the flue pipe exiting the furnace, there is 1/4" gap all around the opening of the furnace, with a warmth exiting from the furnace. Is this supposed to be left to ventilate the inside of the furnace or something? Or can I seal this with appropriate foil tape, etc.?
I have just found sap around a number of rafters in attic and so besides for the attic ventilation exits, I am trying to seal off any systemic heat leaks in attic (not to mention our natural gas bill!).
Thanks.
99altrade is offline   Reply With Quote
Old 12-21-2010, 03:55 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,404
I would leave it open, The design engineers meant it to be that way and you don't want to lessen any combustion air to the burner. It is AGA approved the way it is, altering it negates the approval.
Old 12-21-2010, 05:43 PM   #3
Thanks for the FIRST reply . The others, ehhh, lol - particularly since I don't get the jokes .
Is that first response the consensus here? Leave this space unsealed and allow furnace space where flue exits to leak heat?
Thanks.
Old 12-21-2010, 05:54 PM   #4
Rewards Points: 1,216
Thanks.
Yes that advice was from a Pro.
COLDIRON is offline   Reply With Quote
Old 12-21-2010, 06:38 PM   #5
Yes.
One of the two posting in this thread.
hvaclover is offline   Reply With Quote
Old 12-21-2010, 06:46 PM   #6
Thanks.
Really post a pict. It may help what your seeing. Just remember for every reaction there is a equal and opposite reaction, could b danger.
Hixheat1 is offline   Reply With Quote
Old 12-21-2010, 06:59 PM   #7
Thanks.
You need to think, if u seal off attic. You need fifty cubic feet per. Thousand btu's for proper combustion. Don't play with that math
Seal Space Between Gas Furnace Flue and Furnace? 99altrade Plumbing 0 12-21-2010 11:37 AM
would there be any lead-based coatings inside a gas furnace or flue? Dave Perry HVAC 1 05-14-2010 09:02 AM
Furnace flue height fastfourier HVAC 10 01-18-2010 11:50 PM
Gas furnace flue econoline HVAC 1 11-21-2007 10:00 AM
Replacing My Furnace, few simple questions compression HVAC 10 02-03-2007 06:00 PM
