Screw Size For Metal Duct - HVAC - DIY Chatroom Home Improvement Forum
Old 01-07-2011, 06:35 PM   #1
Rewards Points: 276
screw size for metal duct
I know this isn't something that has to be exact but I like to do things the best way possible. I am running 4" metal duct for my dryer vent and am wondering what size(length and diameter) screws should I use to attach pieces of duct together (not at dryer but throughout run). I will be using hex head screws also. thanks
ugabulldog is offline   Reply With Quote
Old 01-07-2011, 06:56 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 396
I would recommend aluminum metal foil duct tape instead of screws. HDepot should have it. Screws can catch lint. If you must then#8 (1/2") should be OK.
http://www.tapecase.com/c.646.1.1/metal-foil-tape.aspx
Old 01-07-2011, 07:07 PM   #3
Tape for sure, double wrap each joint. Screws are not allowed for drier vents .
Old 01-07-2011, 08:00 PM   #4
An old Tradesmen
Rewards Points: 8,202
Yep, don't screw dryer vent. it will cause thr pipe to clog quicker.
Old 01-08-2011, 07:09 AM   #5
Rewards Points: 276
That's why i was asking, thought screws might catch lint, glad I asked, tape it is!!!! Thanks
Old 01-08-2011, 07:12 AM   #6
An old Tradesmen
This is one of the many things that this forum exist for.
Your welcome.
Jenn-Aire Downdraft - OEM flex duct required? Dwizzo Appliances 0 10-09-2010 04:35 PM
Swapping old 3ways with new (different screw color configuration on new switch) Michblaze02 Electrical 10 11-08-2009 02:17 PM
duct size thumbkins HVAC 1 07-27-2009 10:30 PM
Furnace install in attic - Duct configuration hartkem HVAC 6 11-08-2008 05:46 PM
Need advice on how to screw thru a duct? Chip718 General DIY Discussions 3 04-08-2007 02:28 PM
