Schedule 40 Fitting Help. - HVAC - DIY Chatroom Home Improvement Forum
Old 10-02-2011, 06:10 PM   #1
Schedule 40 fitting help.
So I'e been to many big box stores in search of fittings. My manual calls for 3" vent and intake up until the exit to outside the 2". The problem I am running into is finding a schd 40 3"-2". None of the stores had schd 40 3"-2" but had it in DWV. Can that be used? One store person said that the dwv is schd40. Not sure what is ok to use.
Thanks,
Tim
MNice is offline   Reply With Quote
Old 10-02-2011, 06:29 PM   #2
REP
DWV is a much thinner wall type fitting.
My question is are you sure you are supposed to reduce to 2" going through the wall?You might need such a fitting from the furnace but I'm thinking not at the wall.
That doesn't sound right to me.Call the factory to be sure.
REP is offline   Reply With Quote
Old 10-02-2011, 06:35 PM   #3
Thats what thier manual says for a horizontal run.
Old 10-02-2011, 07:06 PM   #4
Doing it myself
Alan's Avatar
Rewards Points: 2,086
kinda sounds backwards to me.
Journeyman Plumber
Old 10-02-2011, 07:39 PM   #5
Old 10-02-2011, 07:42 PM   #6
You will need to go to a plumbing supply store, or pool and spa supply. The dwv fittings don't last with heat applied to them.
Master of Cold is offline   Reply With Quote
Old 10-02-2011, 07:46 PM   #7
HVAC Tech/ Browns Fan
Do you have a ACE hardware? They sell that there or show them and can make on up at the store. P.S. don't take this the wrong way but that furnace is junk. I had seen the condensate heat exchanger leaks all the time. You really need make sure heat rise is right or after the first year it can crack a coil link.
Tator1076 is offline   Reply With Quote
Old 10-02-2011, 07:58 PM   #8
Thanks for the info everyone. Glad it has 12yrs Warranty.
Old 10-02-2011, 08:01 PM   #9
Do you know how to check heat rise?
Old 10-02-2011, 08:05 PM   #10
Experienced
Jackofall1's Avatar
Why are you using 3" pipe, is it a long run?
Bullet #2 says "When using 3" pipe" my interpretation is the standard is 2" pipe unless the horizontal run is longer the x.
Is there a chart in that manual referencing exhaust lengths? if not then perhaps you could get that info from the manufacturer.
Mark
Old 10-02-2011, 08:05 PM   #11
REP
I'll be damned!!! What a screwey vent.
Old 10-02-2011, 08:08 PM   #12
No. Is this something you dial in once the unit is up and running? I am having the HVAC company i bought the unit from to have them dial in the unit once it's up and running.
Old 10-02-2011, 08:09 PM   #13
Heck if you have this in a basement just use basement for fresh air intake and just run the out take.
Old 10-02-2011, 08:24 PM   #14
Mark
The Unit is 75k. The HVAC person I bought from said i could use 2" "IF" the run was short. I originally bought all the stuff for 2" but after looking at it i didn't feel comfortable with it so I decided to go 3". I need to go 4' vertical to get above my foundation and exit to the exterior. From that vertical the intake will be approx 44" before it is reduce to 2" and the exhaust will be approx 32" before it is reduce to 2".
Old 10-02-2011, 08:27 PM   #15
i would but it changes the code requirement on where it can be located and the distance from windows and doors and im not sure the reasoning.
Copper Y fitting and cabinet install brneilly Plumbing 4 06-30-2011 09:13 AM
leaky copper fitting in supply line for fire sprinkler system tina2435 Plumbing 5 09-18-2009 09:54 PM
How to reuse a ABS fitting guide n0c7 Plumbing 4 08-27-2008 05:30 PM
Cracked PVC fitting in concrete DJupin Plumbing 6 07-29-2008 03:12 PM
