Says Heat, But No Heat - HVAC - DIY Chatroom Home Improvement Forum
Old 01-02-2012, 09:45 AM   #1
vjf
Says heat, but no heat
Any suggestions would be greatly appreciated! I have had this happen a couple times before and am trying to figure it out. The most recent time, someone came out about a month ago and replaced a part for me. On my thermostat, sometimes it says that the heat is on when it is not. I can tell when this is going to happen because when the heat kicks on, it almost takes a few tries to start. You hear the fan and can hear it trying to start, but sometimes it starts right up and other times it shuts off for a second. If it shuts off, then it comes on full force a few minutes later.
It will only be on for a few minutes and then shut off. According to the thermostat though, it says it is on, although it is not. Because of this, it gets cold sometimes! This only happens sometimes though. Please forgive me because I know nothing! I'm just trying to figure out if this is something easy maybe a loose wire on the thermostat or if I need to call someone out?
vjf is offline   Reply With Quote
Old 01-02-2012, 09:57 AM   #2
An old Tradesmen
Rewards Points: 6,928
One of the panels may have a small sight glass, that you can look through and see an error code flashing.
Old 01-02-2012, 10:01 AM   #3
vjf
My furnace is actually in a small room above my guest bathroom. I live in a loft, and that was there they put it so it is not an easy thing to get to! It seems like the easiest may be to have a professional come in and take a look?
Old 01-02-2012, 10:05 AM   #4
An old Tradesmen
Up to you.
VisionPRO Setup Functions & Heat Pump infoskr HVAC 43 07-12-2015 04:28 PM
Heat Pump Thermostat HELP!!! MichaelG HVAC 22 12-09-2010 04:50 PM
Comparison and Heat Pump Selection help... ChrisDIY HVAC 7 03-06-2010 08:34 PM
Heat Pump Woes Zenica HVAC 50 01-27-2009 07:37 AM
Which diagram to use on Lenox Thermostat wiring setup? Heat Pump Lenox techs needed twilightcall HVAC 1 08-13-2008 11:49 AM
