Saving Money On AC? - HVAC - DIY Chatroom Home Improvement Forum
Old 07-08-2011, 02:44 PM   #1
Rewards Points: 562
Saving money on AC?
We're trying to save money on our air conditioning bill. One thing that we've done that's helped significantly is changing the (4) air filters on our return vents from MERV 10 to MERV 6.
Another thing we've been doing is closing off rooms that aren't in use, like our guest room. My question is does closing off room (shutting the vents) really save money? Also, what happens if that room has a return? Should we close that too?
Thanks,
Kelly
kcrossley2 is offline   Reply With Quote
Old 07-08-2011, 03:00 PM   #2
Rewards Points: 6,652
It saves no money closing vents & rooms off. The system is designed for X amount of air flow. If the HVAC company did not calculate in those other rooms, it would not have put a system designed for the size of your home into service. Do yourself a favor, and just keep those rooms open to allow the whole house to stay cool. Basically saying, you are actually causing more problems than it is worth, and no money is being saved.
The Following User Says Thank You to gregzoll For This Useful Post:
kcrossley2 (07-08-2011)
Old 07-08-2011, 03:00 PM   #3
JJboy's Avatar
If turn off your AC you'll save a lot money.
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
The Following User Says Thank You to JJboy For This Useful Post:
gregzoll (07-08-2011)
Old 07-08-2011, 03:09 PM   #4
Rewards Points: 562
I'd love to, but at 95 degrees, with 70% humidity I'll keep the AC on.
Old 07-08-2011, 03:24 PM   #5
Willing to listen
Rewards Points: 223
1. Install a programmable thermostat if you don't have one and use the programming feature.
2. Use ceiling fan(s)
3. Pay for annual maintenance to make sure things like refrigerant charge are correct and you are getting the efficiency/cooling you are paying for
4. Seal duct leaks you have access to. If you have any flex duct check it's insulation and that it's hung properly w/o kinks etc
5. Weatherstripping, caulk, wall & attic insulation, window tinting & insulated blinds, etc...whatever you can do to reduce the load the AC has to deal with.
6. Have a PSC circulator motor upgraded to an ECM type. Pretty long payback on this though.
Just some random ideas to get you thinking.
Done That is offline   Reply With Quote
Old 07-08-2011, 03:39 PM   #6
JJboy's Avatar
Don't close vents. Set your thermostat to 78 all the time. Keep condenser and evap coils clean and system charged.
Old 07-08-2011, 03:40 PM   #7
Rewards Points: 562
What about using the recirculate feature on the programmable thermostat?
Old 07-08-2011, 04:25 PM   #8
An old Tradesmen
Rewards Points: 8,202
Should use a MERV 8 filter, to keep your evap coil cleaner longer. Closing off vents is not a good idea.
Old 07-08-2011, 04:55 PM   #9
Hvac Pro
yuri's Avatar
Rewards Points: 396
merv 8 is the minimum I use. make sure you keep the outdoor coil clean/flush it once a month with the garden hose. make sure ALL doors weatherstripping is new and intact and also for the attic hatch. buy those foam insulation strips that go behind your electrical box plugs and light switches on exterior walls, snoop around the HDepot doors and windows and weatherstripping dept for more idea. All the small air leaks add up to one big air leak and wasted NRG. good quality blinds/drapes for the windows and shades blocks a lot of sun/heat and pays big dividends.
Old 07-08-2011, 05:15 PM   #10
Yea. Its definitely too hot to turn of the AC.
Thats why its important to do. HVAC maintenance
Anddy is offline   Reply With Quote
Old 07-08-2011, 07:01 PM   #11
Rewards Points: 150
Find out from your electric co when the peak hours of use are, during these hours you pay double and triple and some days 10 times normal rate. Where we live those hours are 2-7 p.m. So during those hours raise the temp on the ac, don't run the dryer, stove, oven or anything with a high wattage. If you are diligent you can save some money.
josall is offline   Reply With Quote
Old 07-08-2011, 07:07 PM   #12
Hvac Pro
yuri's Avatar
Rewards Points: 396
Turn up the AC, suck back a few beers in the wading pool and be Happy!
Old 07-08-2011, 07:18 PM   #13
Experienced
Jackofall1's Avatar
You could always run an extension cord to your nieghbors
The Following User Says Thank You to Jackofall1 For This Useful Post:
Tizzer (07-09-2011)
Old 07-08-2011, 07:26 PM   #14
I have the best suggestion: move to north pole !
clocert is offline   Reply With Quote
Old 07-08-2011, 08:06 PM   #15
Does not work with my utility, which is city owned. Right now, it is 12 cents/kwh. I have been tracking my use on the wifi thermostat with a 3rd party application. One day, it ran for 13 cycles, 1335 minutes, and cost $6.27, with the thermostat set at 72. Any higher, and it becomes uncomfortable in the house.
This http://thermostatmonitor.com/ is what I am using with the thermostat to track use, and costs.
Wow, I got money coming beenthere Off Topic 12 01-21-2010 01:28 PM
Money Saving Information diyclueless Introductions 2 10-29-2009 06:18 PM
Make Money At Home! (A discussion about Scams) gma2rjc Off Topic 21 02-16-2009 08:46 PM
I'm all about saving money on electricity but what is this? imola ghost Electrical 15 09-09-2008 08:36 PM
