Saving The Fire Place. - HVAC - DIY Chatroom Home Improvement Forum
Old 02-02-2013, 02:23 PM   #1
Saving the fire place.
Was very pleased with the fireplace when we moved in here. But dismayed when we tried to use it. Turned out the flu damper was mortared shut. From the outside. By cutting some access holes through what would be the outside chimney surround I found there was a chimney there at one time. And found the mortar nicely slathered over where the smoke box should be. Apparently there was never any use of fire brick in the past. At one time it burned natural wood, but now has gas logs. We have yet to use them ourselves. No venting of gas logs just seems like not a good idea to me. (This may be a long post...) I want to line the fire place with fire brick, of coarse, but need to (re)construct the smoke box and chimney. Where can I dig up dimensions for a smoke box that's appropriately sized for this rather large and nice looking fire place? Chimney building will be the next level of concern.
mrcaptainbob is offline   Reply With Quote
Old 02-02-2013, 10:21 PM   #2
Rewards Points: 610
Are you sure the gas fireplace is not of the direct vent type which would be vented via a vent pipe directly to outside. I'm not that familiar with gas fireplaces but, it sounds logical to me. Not sure how to definitely determine though. ( if it is...should be vent on outside wall) Maybe get a fireplace installer to check and let you know what can be done.
OR if firebrick and chimney required just get it converted to direct vent unit.
techpappy is offline   Reply With Quote
Old 02-02-2013, 10:25 PM   #3
Rewards Points: 13,732
Call a mason on this one.
Old 02-02-2013, 10:47 PM   #4
Rewards Points: 610
YES.. If you really want to convert back to wood burning then a good stone mason is a must..these guys are worth their weight in gold. Do not guess on size of fireplace/smoke box...paying for hour for an experienced mason would be the right way to start.
Old 02-03-2013, 01:43 PM   #5
Good suggestions....
Not all that interested in it being a natural log fireplace. Maybe I should for somebody in the future. That way it would be dual use. As for it having an outside vent...I found no openings to the outside. Inlet or outlet.
Old 02-03-2013, 01:54 PM   #6
HVAC Tech/Owner
Rewards Points: 604
Are they vent-free gas logs?
Technow is offline   Reply With Quote
Old 02-03-2013, 09:42 PM   #7
Vent free logs....
I don't know, Technow. How can I tell? Is there a label or tag on the burner assembly?
Old 02-04-2013, 06:05 AM   #8
HVAC Tech/Owner
Rewards Points: 604
There is supposed to be a tag.
Old 02-04-2013, 01:07 PM   #9
Fireplace logs....
The 'logs' are a pretty delicate material. They look like smallish branches between 1.5 and two inches diameter. I remember seeing a tag on the floor in there when we first moved in. I'll check it today and report back.
SCARY oven fire! Why did it burn? Beth777 Appliances 73 09-03-2016 02:19 PM
Gas Fire Place shawnmurray Appliances 0 12-29-2011 08:47 AM
help me light my fire place....please bob barker General DIY Discussions 4 11-16-2010 09:30 PM
Fire blocking? Can you use liquid nails? Leoskee Building & Construction 8 09-16-2009 11:02 AM
Laminate Flooring around a brick fire place pamedic13 Flooring 6 11-21-2006 08:42 PM
