-   -   Sanyo ks0971 split system (http://www.diychatroom.com/f17/sanyo-ks0971-split-system-31899/)
crane doc 11-15-2008 07:52 AM
Iam having trouble with the heating side of the system.It turns on and the red led it constantly blinking red.Iam sure this is a trouble code but i dont know whay it means,Thanks any help appreciated.
HvacWiz 11-15-2008 11:11 AM
Look on the back of your furnace door, maybe the fault codes are listed there.
kennzz05 11-15-2008 11:11 AM
need to look in your manual is the outside unit running?if so if there cold air coming out of it colder than ambient
crane doc 11-15-2008 11:32 AM
The owners mannual does not get that involved, outside unit is not running.removed the cover on the outside unit did not see anything obviosly wrong, checked power to the unit it is there.
kennzz05 11-15-2008 11:44 AM
try googleing i was able to come up with the install guide which of course isnt helpful although it does describe putting it in a test mode i have installed alot of these ductless splits but mostly fujitsu and never really had problems with them so other than a little internet sluthing im no help
crane doc 11-15-2008 12:26 PM
The troubleshooting guide tells me that the circuit board in the wall unit is bad.Trying to find the circuit board on line not having no luck
kennzz05 11-15-2008 02:56 PM
call sanyo tech support on monday unless there a 24 hr facility good luck and y/w
dont forget to check the warranty there may be a five yr on the control boards
