Samsung Window Air Conditioner - HVAC - DIY Chatroom Home Improvement Forum
Old 04-28-2014, 10:00 AM   #1
Hi, Guys. I have a 14.5K BTU Samsung window unit. Whenever the unit is plugged in only the compressor comes on without the fan. The control panel and the display seem to be dead. Should I check for voltage at the fan? Is this most likely a dead control board? If so, how should I test for that? Thank you for any advice.
jeruss is offline   Reply With Quote
Old 04-28-2014, 10:19 AM   #2
Rewards Points: 14,000
And the model # is?
110 or 220?
Old 04-28-2014, 10:30 AM   #3
It runs on 110. I will post the model # this evening when at home. Thanks for your help.
Old 04-28-2014, 08:26 PM   #4
The model number is AW15ECB8 and it is a 14.7K BTU unit.
Old 05-21-2014, 01:05 AM   #5
airtrackinc's Avatar
Rewards Points: 82
First check the fan motor
airtrackinc is offline   Reply With Quote
Changing Window Size TinaV Remodeling 3 11-06-2012 12:30 PM
Window Stool Removal Issue bperk21 Windows and Doors 4 04-21-2011 06:03 PM
Removing a window for painting... JJDoherty General DIY Discussions 6 08-31-2010 08:39 PM
Installing window air conditioner mary60 Electrical 1 08-14-2008 06:25 PM
Window air conditioner pwallyp Electrical 3 03-10-2007 10:04 AM
