Old 08-10-2012, 10:41 AM   #1
safety overflow switch trane xl14i
With the switch in the housing the unit will short cycle. Remove the switch the unit operates normally.
Trane authorized dealer serviced the unit to no avail.
Condensate line is clear...no water in the safety switch elbow,
Unit is located in the garage.
jeffrey sehl is offline   Reply With Quote
Old 08-10-2012, 10:46 AM   #2
good luck
Old 08-10-2012, 11:15 AM   #3
Did he even check the switch to see if it was working properly?
Wiring in a 4-way Switch RickSene Electrical 5 04-09-2013 08:25 PM
Drain Pan Safety Switch/ shut off switch firedogut HVAC 6 10-13-2009 08:52 AM
Switch safety sockets Arek Safety 5 10-07-2009 04:16 PM
100 amp Safety Disconnect switch alvinbga Electrical 7 05-16-2008 12:11 PM
Generator Safety Switch Help - Breaker Size? limey_swindon Electrical 3 01-09-2008 12:40 PM
