S9301A1001 Integrated Boiler Control - HVAC - DIY Chatroom Home Improvement Forum
Old 11-01-2008, 12:57 PM   #1
Hi,
Hope someone can help,
Was advised by a retired plumber that the Honeywell integrated boiler control S9301A1001 on our Weil Mclain furnace has a recall on it....could anyone out there please confirm this,
Also what would be the symtoms of this fault and also the steps forward in regard to getting this changed.
Many many thanks.
Invisible-Man is offline   Reply With Quote
Old 11-01-2008, 01:17 PM   #2
Call Honeywell. They will be able to tell you and tell you how to get the thing exchanged. Many times they will send you a new one and bill your credit card. Then when you return the old one they will give you a credit.
My idea of a perfect day: No where to go and all day to get there.
Marvin Gardens is offline   Reply With Quote
Old 01-17-2009, 05:48 AM   #3
boiler control
Originally Posted by Invisible-Man View Post
Hi,
Many many thanks.
Hi, I saw your thread and I have the same part in my boiler and I'm having a problem. The boiler keeps cycling. Did you have the same problem and did honeywell correct this for you? Thanks Steve
sking58 is offline   Reply With Quote
Old 03-31-2009, 09:49 PM   #4
Talking
Just fixed mine
I just re-flowed the solder on the 24v connector, a relay leg and a control pin on the board. It seems to be working the house is up to 62f. -Tim Western Tip o' Lake Superior.
Colombo is offline   Reply With Quote
Circulation pump on boiler uncleneiler Plumbing 4 06-22-2010 09:01 AM
Boiler Shut Down SassySue General DIY Discussions 3 01-01-2008 11:49 AM
How can I increase PSI in my boiler? (pics attached) drh HVAC 3 12-18-2007 05:26 PM
Boiler Options -Will Boiler be good enough??!! deano54321 Plumbing 2 10-28-2007 06:18 PM
