Old 01-12-2011, 10:50 PM   #1
RV suburban furnance
Hello,I have recently come across a jag rv with a 3 wire thermostat.The green wire is loose and hot,red and white are connected to two blue wires to the unit.the furnance fan blows and sounds like the ignitor is ticking in but no combustion.Thinking that the loose green wire is the solution but whear does it tie in at?Anybody know?Thanks for any possiable help.
rick
rockingr is offline   Reply With Quote
Old 01-12-2011, 11:26 PM   #2
hvaclover's Avatar
need to see the wiring diagram.
Just slow, not stupid.
hvaclover is offline   Reply With Quote
Old 01-17-2011, 12:33 AM   #3
I ran across a similar trailer at a gas station, talked to the owner whom allowed me to take off the return air grill n guess what ?Yup,only the red and green wires were connected to the unit and the white wire was cut off.So, I did the same thing and it all runs great.Next best thing to a diagram , right.
lil slow
Old 01-17-2011, 07:09 AM   #4
Got gas at the gas valve? Go on RV.NET or look up wiring diagrams for RV heaters Suburban on line I am sure you will get it.
COLDIRON is offline   Reply With Quote
Quatro Mba 080 NH2R furnance manual wolfden13 HVAC 1 02-10-2010 05:26 AM
Furnance question. diy4life Building & Construction 29 12-01-2009 06:39 PM
Furnance question satz HVAC 8 02-05-2009 08:44 AM
Furnance burner won't stay on. 2007ken HVAC 11 03-04-2008 12:29 AM
oil furnance "boom" when starting hvac novice HVAC 5 11-21-2007 01:56 PM
