RV Furnace Not Lighting - HVAC - DIY Chatroom Home Improvement Forum
Old 11-15-2011, 01:38 AM   #1
Question
I'm having trouble lighting my '86 Suburban Dynatrail Propane Furnace. When I try and turn it on, all that happens is the fan starts blowing and a spark flashes behind the burner access door. The propane is full and on as is the manual shut off valve. Could it be my solenoid valve inside, and how do I check it?
I appreciate any help anyone can offer.
rvfoodtruck is offline   Reply With Quote
Old 11-15-2011, 07:55 AM   #2
Rewards Points: 1,214
Spiders love propane check all the supply gas lines to make sure some hairy little creatures didn't move in. TIP< in the Winter when you close up the RV take a couple cups of mothballs and put one in each compartment , hot water heater, heater, refrigerator. They will not go near it.
PS> Near each burner.
COLDIRON is offline   Reply With Quote
Old 11-15-2011, 01:03 PM   #3
You use moth balls in a RV and you will regret it for years to come......
Propane is extremely flammable and very dangerous to a untrained person. Turn off the LP at the source (the tanks) then carefully remove the pilot assembly and throughly clean it. after that if it still does not not light then have a professional look at.
harleyrider is offline   Reply With Quote
Old 11-15-2011, 03:00 PM   #4
Been Rving for 40 years, do not put moth balls inside the Rv you put them outside at the gas burners in the vent compartments. Learned that trick many years ago from RV Seminar. If you an RVer you know what I am talking about.
Old 11-15-2011, 04:28 PM   #5
my 40 ft travel trailer has the furnace on the inside...........
Old 11-15-2011, 04:33 PM   #6
Hvac Pro
yuri's Avatar
Rewards Points: 1,096
You can really live in some of those trailers. One of my customers runs a trailer/RV store and says they have washers and dryers etc. Bigger than my first apt.
Old 11-15-2011, 06:58 PM   #7
I know I owned a 18' Nomad, 27' sunline, 18' Mallard, 30' Four winds Class C motor home, now a 40' park model Innsbruck with 3 slides, yes you can live in them.
Old 11-15-2011, 07:09 PM   #8
Hvac Pro
yuri's Avatar
I wonder how much dope you can grow in one of them. LOL. We just had a house with 1500 plants in it busted the other day. $500,000 house in a nice area.
Our favorite dope growin/smokin Canadian boys ( The Trailer Park Boys ) set up shop in one of the silver oven lookin jobs on one of the shows.
Rock On
Old 11-16-2011, 07:19 AM   #9
The 3 guys should look happier, maybe they ran out of munchies or papers.
Tags
furnace , solenoid valve , suburban
Gas furnace not lighting y0ungshel HVAC 8 10-30-2011 05:48 PM
Heil Gas Furnace Not Lighting kasi42 HVAC 21 10-09-2010 05:40 PM
oil furnace not lighting b4322558 HVAC 8 09-26-2010 11:11 PM
Help! with Concord 80+ gas furnace + T-STAT joryeln HVAC 0 09-16-2009 01:23 PM
Problem with Trane gas furnace quovadis HVAC 17 12-22-2008 02:12 PM
