Old 11-09-2011, 03:42 PM   #1
Arrow
Ruud UGAC-O6KC
Need help...
Ruud Furnace
Model UGAC-O6KC (0orO)
Serial TN3D104 F2083 6467
electric ignition, when I watch it, it clicks, the ignitor does not light the pilot. I manually light the pilot, after about 30 seconds, the pilot clicks and goes out. about 15 seconds later it click again but does not light, I light it again, the burners do not light,. I have cleaned the rod that is supposed to tell the sensor there is a flame? I just moved in here it was inspected, and ok'd I can't figure it out. PGE is coming on the 15th I'm freezing. Thanks for any help.
emeraldfrogy is offline   Reply With Quote
Old 11-09-2011, 08:15 PM   #2
Ruud UGAC-O6KC
obviously the ignition module is bad........
harleyrider is offline   Reply With Quote
Old 11-09-2011, 08:32 PM   #3
how
Ruud UGAC-O6KC
I think harley has it right but just in case its a partially obstructed pilot.....
when you manually light the pilot, does the pilot flame fully envelope the flame sensor?
Do you see the spark when it clicks and is that spark in the path of the pilot flame?
how is offline   Reply With Quote
Old 11-09-2011, 08:44 PM   #4
Ruud UGAC-O6KC
No Flame at all, it clicks, but nothing. When I light it, it is a large flame coming from 2 different small pipes one points to the burners, one to the heat rod. It should light, but apparently nothing is telling it to.
Old 11-09-2011, 09:17 PM   #5
how
Ruud UGAC-O6KC
It seems like both the electronic ignition and the flame sensing system is at fault so the ignition module is the part to change.
Tags
burners, pilot, rudd
Ruud vs Trane peter_holmes HVAC 23 07-28-2010 03:32 PM
Ruud heat pump high pressure switch mikethe ductman HVAC 3 07-28-2010 07:00 AM
Ruud help tritrinh HVAC 3 12-05-2009 11:47 PM
Ruud Service Manual, Pros don't want me to understand my system Ruuduser HVAC 56 03-29-2009 07:45 PM
Ruud a/c control board replacement ? kourso HVAC 1 07-20-2006 10:33 PM
