Ruud Silhouette II Furnace Problem - HVAC - DIY Chatroom Home Improvement Forum
Old 11-14-2010, 05:52 PM   #1
Hi;
I have a ruud furnace (UGPH-05EAUER) that wont stay running. The unit goes through the start up cycle. The electronic igniter will start sparking, and
the flame will ignite. It will run good for about 5-7 seconds, then
it it will go out like the unit cut the gas off. I think it is probably a
flame sensor issue, but I am not sure what it is called.
This furnace has a circuit board with 3 leds. Two are green and one is
yellow. It says Flame. This light flashes about once every second while the gas is burning. It goes out immediately after the 5-7 seconds when the gas is cut off. The other two leds stay solid green. I cant find a manual to see how to read these. Any help or pointers would be appreciated.
komobu is offline   Reply With Quote
Old 11-14-2010, 06:24 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 2,290
Remove and clean the flame sensor with fine steel wool or emory paper. Should look like this and sit in front of one of the burners.
Old 11-15-2010, 05:03 PM   #3
Yuri;
Thanks so much for taking the time to reply. I cleaned the tip and it is working great. Thanks Again!
Old 11-28-2011, 04:27 PM   #4
Same problem only different
I have cleaned the sensor 3 or 4 times and my furnace still won't stay lit. I have the board with 3 lights and the flame light never comes on during start-up. I also cleaned all the burners ad checked most of the connections on the circuit board. Can anyone suggest anything else I can check? Oh yeah, it was working yesterday...
Gitfiddler
Gitfiddler is offline   Reply With Quote
Old 11-28-2011, 05:32 PM   #5
Gitfiddler
Do you have a multi-meter? Only way to know for sure what's going on is to get a DC microamp reading from the flame sensor and check AC voltage from the sensor wire to ground.
Old 11-29-2011, 05:23 AM   #6
Thanks Marty, I read in another thread where you said that the reading should be 1.8 microamps or over when the flame is on the rod...my question is where do I place the pos. and neg.? Also what should te reading be with no flame?
Old 11-29-2011, 06:41 AM   #7
The control board sends AC voltage to the flame sensor which jumps through the flame and returns to the board via ground(burners first) as DC voltage. First step would be stick one lead of meter on the spade connected end of the flame sensor and the other to ground. With a call for heat you should have 28-80 volts AC. Actual voltage depends on which control board and I do not know the specific range on yours. If no voltage then the board is bad.
To check the microamps disconnect the wire on the flame sensor and put the meter between the sensor and the wire(set to DC microamps). With no flame there can be no microamp reading since the AC voltage needs to go through it to be rectified to DC. If the sensor is clean(and insulator not cracked or fouled with carbon) with AC voltage coming from the board(confirmed in step one) and the DC microamp reading low then the problem is the return path through ground. Most often that's surface rust on the burners.
Edit-Had a UGPH today and it was 100 volts to the flame sensor and 3.2 microamps.
Old 11-29-2011, 05:09 PM   #8
Thank you kind sir, I really appreciate the help!! It's nice to have someone like you around when us HVAC morons have a prob! I'll try these steps and let you know the outcome.
Gitfiddler
Old 11-29-2011, 05:38 PM   #9
I'm just trying to avoid having to hook up a gazillion BTU AC in the afterlife. Hopefully these good deeds will offset my teen years
Old 12-01-2011, 04:56 AM   #10
I decided to take a short-cut and was able to obtain a flame sensor that would work. Still no joy, so I went and bought yet another filter, put that in and took apart the wiring connections and did a cursory cleaning...I blew any dust and crud out of them and put them back together...all of a sudden everything works perfect!! I even put the old sensor back in. Been nice and toasty all night...I think sometimes if you go the simple route it's sometimes the best one!!
Old 03-26-2014, 02:09 PM   #11
furnace issues
I am having an issue with my furnace ,it will not ignite it was working yesterday but now nothing anybody know what I should do at this point
buckeye02 is offline   Reply With Quote
Old 01-17-2016, 03:18 PM   #12
Rewards Points: 8
Did not see where to post new thread. Need to find out why bottom burner where flame sensor is; is not lighting. Top three burners are going.
regnell1500 is offline   Reply With Quote
Old 01-17-2016, 04:24 PM   #13
Hvac Pro
yuri's Avatar
Burner could be dirty or your gas valve is not producing enough pressure. Also could be debris in the orifice of the burner and in some parts of the US apparently spiders get in there and nest/plug them.
Most likely the burner is dirty. There is a crossover/connector channel between the burners which may be plugged and not letting the flame cross over to light the burner.
Old 01-17-2016, 05:01 PM   #14
Rewards Points: 8
Thanks for the most helpful reply; but with the unit and gas turned off. Is it safe to remove the burner. Seems to only be two screws holding it. And I would like to know if the burner itself could actually be bad. Thanks
Old 01-17-2016, 05:27 PM   #15
Hvac Pro
yuri's Avatar
The burners can be a bit difficult to remove and line up on that furnace. I would recommend you get a Pro to do it. If it is not lined up perfectly later you could get delayed ignition or a fire. The burner is not likley bad unless it is extremely corroded or burnt thru and I cannot see it.
When you get a burner that won't light that is a VERY serious DANGEROUS condition because gas can build up in the chamber and light later and create a big boom or explosion. Not something to be taken lightly or fooled around with.
If the gas pressure is low you need a manometer to check it. Not something I recommend DIYers do.
The Following User Says Thank You to yuri For This Useful Post:
regnell1500 (01-17-2016)
Payne furnace problem Laughingchi HVAC 26 05-24-2015 03:59 PM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
Another Keeprite Electric furnace problem lrad Electrical 0 10-18-2010 12:24 PM
Carrier Furnace Problem... cornation71 HVAC 3 12-10-2009 07:52 AM
Ruud Furnace Problem patiofurniture HVAC 1 09-23-2009 07:14 PM
