Ruud Pack Unit "KABOOMS" Upon First Light Up Of The Day! - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-23-2008, 08:36 PM   #16
I'm having a similar problem. I have three cracked heat exchangers and have just replaced them. I put the unit back in service and it still goes boom. The ignitior will cycle and then the furnace will ignite for just a split second and then flame out. I was wondering if you have found a fix.
plunked is offline   Reply With Quote
Old 12-15-2012, 08:26 AM   #17
i know you would like to kepp it longer .one thing to consider is how much money worth of propane you burn, if you repaced the unit with a dual fuel heat pump package unit you would save money on heating cost
mrairflow is offline   Reply With Quote
Old 12-15-2012, 09:31 AM   #18
An old Tradesmen
Rewards Points: 6,550
This is a 4 year old thread.
Old 12-15-2012, 11:11 AM   #19
Roofmaster
Rewards Points: 2,172
Im not an HVAC Tech, yet. But to me, what is happening sounds simpler than all of the other explanations. Since it only happens the first time that it lights, and usually after it sits a while, it is a miniscule gas leak. I bet the gas valve was manufactured with a gasket that was gas permeable or something ridiculous like that. I would do a search and see if you can find a recall on that valve. I would also go ask the neighbors that had theirs replaced if they have any info on it. KISS Rule.
Side Bar: When I was young we had a Gas Stove that had no pilot for the oven. There was a hole in the bottom front that you dropped a match down to light the Oven. My Mom constantly told us NEVER, NEVER turn on the gas before you light the match. Light the match, turn on the gas, drop the match down the hole. I listened. My older brother, who was a teenager and knew everything did not. He had his hair like Elvis. Greased up DA and all. One day he lit the oven to heat up a frozen pizza.............................. Im still laughing at 66
Pilot Light Won't Stay Lit etiger1 HVAC 7 10-19-2009 08:09 PM
Need to replace can light with standard light Woodcutter Electrical 3 02-29-2008 08:06 AM
Ruud 80 plus unit, itermittently no heat paul murphy HVAC 12 01-06-2008 11:57 PM
Trying to replace wall mounted light fixture jtm2300 Electrical 4 08-03-2007 10:44 PM
Hot Light Outlets Materials Guru Electrical 5 07-31-2006 08:11 PM
