Ruud Natural Gas Furnace Occasionally Will Not Turn On - HVAC - DIY Chatroom Home Improvement Forum
Old 01-29-2009, 05:37 PM   #1
Question
Ruud natural gas furnace occasionally will not turn on
About 15 yrs old, clean, yes some rust. Seems to run fine for a week, then will not turn on. Replaced electronic thermostat (but now know that was not the problem). Have removed thermostat and used jumpers to cause gas to open (flame, has pilot light) and use another jumper to start fan. But now that is not working consistently. Used multimeter and there is voltage with Red and White (gas) and Red and Yellow (blower). Is there a way to test the 3 sensors that are wired in a series? What is a typical - based on experience - cause… to help me to know where to start to look. Thanks!
BillyT1 is offline   Reply With Quote
Old 01-29-2009, 07:38 PM   #2
JohnH1's Avatar
I belive you are saying you have a standing pilot (IE: always lit) and upon a call for heat nothing happens. Is this correct? Then tell us what you have to do to get unit operating again. Also assuming your wires are color coded correct if you jump the R to Y you will be starting the outdoor a/c. R to G is the fan only.
JohnH1 is offline   Reply With Quote
Old 01-30-2009, 01:11 PM   #3
Thank you for the comments. Last evening, furnance would not turn on no matter what I tried. So, have a service call in. I will update here with the result to add to this knowledge base.
Old 01-30-2009, 04:42 PM   #4
Well it was the gas valve... brand: Robertshaw.
Must have been going bad for a while. That would explain the intermittent working. OK, purchased and installed right at $250. Now got heat!
Pilot light button on furnace won't turn whydonchathen HVAC 8 01-19-2015 11:40 AM
Comfortmaker furnace won't turn on steelframe8459 HVAC 36 11-30-2011 04:22 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
Ruud Furnace fan won't turn on Suzy HVAC 1 02-04-2008 06:36 PM
Help Please, Furnace won't turn on lh0628 HVAC 8 10-09-2007 04:07 PM
