Old 12-05-2009, 06:55 PM   #1
Ruud help
I've a 13 year old Ruud air conditioning system includes cooler and heater. It works well untill 2 days ago, the heater stopped. When I turn it on, the blower works without heat. The Ruud model number is RCBA 4882 GG21 (also found anther model number UBHÁ J20SFCA). Please tell me what is wrong and how to fix it. Thank you.
tritrinh is offline   Reply With Quote
Old 12-05-2009, 07:27 PM   #2
Hvac Pro
Ruud help
The limit control is probably blown from lack of airflow. Not sure where it is on your unit. Somewhere close to the burners and above them.
Old 12-05-2009, 10:46 PM   #3
Ruud help
Thank you for your answer, Mr. Yuri. But the air out of the vent is strong. I don't think the problem is from the air flow control. Maybe there is something wrong with the burner. Can they be broken? How can know the burner work or not and how to replace them.
Old 12-05-2009, 11:47 PM   #4
Ruud help
When a limit is tripped the blower comes on as a safety to cool the unit down. If the blower comes on right away then the limit is probably bad. Yuri was stating the most common cause of a limit failure,bad airflow. Test it with a meter to find out for sure.
Tags
ruud heater
Ruud vs Trane peter_holmes HVAC 23 07-28-2010 03:32 PM
Ruud Service Manual, Pros don't want me to understand my system Ruuduser HVAC 56 03-29-2009 07:45 PM
Ruud Furnace Draft Inducer Fan Does Not Come On Little Joe HVAC 3 11-11-2008 07:10 PM
Ruud a/c control board replacement ? kourso HVAC 1 07-20-2006 10:33 PM
