Ruud Heat Strip Furnace Blower - HVAC - DIY Chatroom Home Improvement Forum
Old 03-05-2010, 02:13 PM   #1
Ruud heat strip furnace blower
I am having trouble with a ruud heat strip furnace. Sometimes the blower will start fine as it is supposed to. Other times, it won't. I have upgraded the therm to a digital and the blower relay has been replaced. Still have the same intermittent problem. Any advise?
Tkelly
TKELLY is offline   Reply With Quote
Old 03-05-2010, 03:05 PM   #2
30 year tech
hvac122's Avatar
Without knowing what model furnace or thermostat you have I will just guess. Is there a switch on the back of the thermostat for a option of gas or electric furnace? Otherwise it could be a sequencer not working right?
hvac122 is offline   Reply With Quote
The Following User Says Thank You to hvac122 For This Useful Post:
TKELLY (03-08-2010)
Old 03-08-2010, 09:04 AM   #3
Tkelly
The problem began before I upgraded the stat. I don't have the model number available right now. Do all units have a sequencer? Is this all that would make the unit's blower not come on when it is supposed to when the relay and stat have been ruled out?
Old 03-08-2010, 11:28 AM   #4
30 year tech
hvac122's Avatar
How old is this air handler?
What model do you have? With this info maybe a Ruud person could answer your questions on what is controlling the fan.
Have you checked for power to the fan when it will not come on to see if it may be the fan is out on a overload?
Old 03-08-2010, 02:09 PM   #5
The unit is about 15 yrs. old. Will get the model #. I will check for power to the motor when if acts up. Thanks again Lincoln.
How to stop auxillary heat from coming on defrost cycle and limit auxillary heat use? twilightcall HVAC 34 12-28-2010 06:53 PM
Goodman Heat Pump - Blower Motor FireFighter254 HVAC 9 03-05-2010 06:18 AM
Bizarre Heat Pump and Blower Behavior gatorinsc HVAC 3 01-11-2010 03:32 PM
Heat Pump Blower always on gg_daman HVAC 1 12-16-2009 06:15 AM
first time startup on Bryant furnace - furnace calls for heat and will not stop luvheat HVAC 22 02-14-2009 08:56 AM
