Ruud Heat Pump Strips Heat No Fan - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-29-2012, 07:05 PM   #16
It's a Honeywell Pro 5000
Bobwoodberry is offline   Reply With Quote
Old 02-29-2012, 07:09 PM   #17
Hvac Pro
yuri's Avatar
Rewards Points: 1,146
I looked at your other posts and see it is a heat pump. That is a good tstat and non power stealing. I am not too familiar with heat pumps but I suspect a short in the low voltage wiring inside the heat pump or between the tstat and furnace/air handler. I have had wires get chewed by rodents, cats inside the house, rubbed against ducts and staples and shorted. May want to run a new wire from the tstat to the air handler and start over and yes that is a dangerous situation and will wreck the heat strips/elements. U can get 18/6 LVT wire at HDepot by the foot or roll. It is protected from abrasion and better than plain wire. DO NOT use telephone wire!
The Following User Says Thank You to yuri For This Useful Post:
Bobwoodberry (02-29-2012)
Old 02-29-2012, 07:15 PM   #18
An old Tradesmen
Rewards Points: 6,140
Don't hi jack other peoples threads. Your post in that thread have now been merged with this one.
Old 02-29-2012, 07:43 PM   #19
AKA HVACTECHFW
Rewards Points: 1,208
delete
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 03-03-2012, 09:56 AM   #20
Well been busy but 2 days ago I took the black and white wires off of the t-stat (E and Aux) So far have had no issues. Picked up new stack contacts- sequencers yesterday (not sure exact name). So I'm thinking now after the sequencers are changed if it still happens it must be a short in the wiring like was suggested. Thanks to all who have responded and by the way I in no way intended to hijack someone's thread, I figured if two people had the same issues we could learn from each other.
Bob
VisionPRO Setup Functions & Heat Pump infoskr HVAC 43 07-12-2015 05:28 PM
Heatpump vs Natural Gas - Energy Cost Spreadsheet zootjeff HVAC 11 06-22-2015 04:59 AM
Heat pump vs AC unit docmattman HVAC 11 07-31-2011 12:24 PM
New Heat Pump..questions? ddave23 HVAC 4 03-05-2010 06:13 AM
Heat pump vs in floor heat mugen HVAC 5 03-02-2010 09:18 PM
