Ruud Heat Pump High Pressure Switch - HVAC - DIY Chatroom Home Improvement Forum
Old 07-27-2010, 10:47 PM   #1
Rewards Points: 85
Ruud heat pump high pressure switch
Did a job a couple weeks ago for some guy, he sent me to another job.
He said service valve was leaking and he wanted me to fix it, he also said the defrost board was bad.
The leak was two copper pipes rubbing each other, the defrost board was still good he just took the H/P switch out of the loop.
I have seen this a lot with Ruud units.
So what up with Ruud H/P switchs?
mikethe ductman is offline   Reply With Quote
Old 07-28-2010, 12:28 AM   #2
An old Tradesmen
Rewards Points: 6,060
Its usually not the switch. But the way its installed. Or, its overcharged.
On the old short air handlers. If the regain collar wasn't made. Techs would over charge them in cooling mode. Which made them trip the HP switch in heating mode.
Old 07-28-2010, 06:27 AM   #3
Rewards Points: 85
The name plate said 124 oz.
The charging chart said the head pressure on a 85 degree day should be 205
I put in 120 oz. and the head was 205
House temp. was 85 supply air was 64.
Old 07-28-2010, 07:00 AM   #4
An old Tradesmen
Make sure both coils are clean. And check air flow.
Heatpump vs Natural Gas - Energy Cost Spreadsheet zootjeff HVAC 11 06-22-2015 04:59 AM
How to stop auxillary heat from coming on defrost cycle and limit auxillary heat use? twilightcall HVAC 34 12-28-2010 07:53 PM
Need help from control guys or heat pump gurus (reversing heat pump defrost cycle) pomelo HVAC 11 03-08-2010 09:13 PM
New pressure switch and inducer and still incorrect drafting kevintabb HVAC 5 01-19-2010 01:59 PM
Heat Pump Woes Zenica HVAC 50 01-27-2009 08:37 AM
